Which fog lights to with on a CG 05;' TSX
i want xenon match bulbs, but searching for them is a beeotch, anybody know some good ones off the top of their head? That's probably the only thing stopping me from getting fogs, i really dont want yellow
I was thinking of going with http://www.hoen-usa.com/fog.htm the H11's?? What do you think. They are supposed to be a Xenon match.
I have these and they look great PERFECT!! Wish they still made H1s. Went with Philips and they are a little more blue.
You can buy a HID conversion kit for about 300, that installs into the fog lights, its basicly a bulb replacment.
http://www.xenonking.com/3000.htm
Make sure those HID upgrades aren't too bright and don't throw too much light around or you'll be a hazard to other drivers and a target for law enforcement.
As for the bulb color, I recommend the Nokya yellows. Functionally, yellow/amber light is far superior to whiter colors in inclement weather, which is what fog lights are designed to work in. Yellow produces much less perceptible glare to the human eye than whiter colors do, so it increases visibility greatly. Same reason why ships and aircraft use red interior lighting at night to preserve the crew's night vision.
Oh and I have the Nokya H11s.
Originally Posted by TSX.Fury
I can't wait for our photoshoot
What do you guys think about Nokya Hyper Yellow H11 versus Luminics JDM Yellow H11.
Nokya draw is 55 and output is 80
Luminics draw is 55 and output is 130
http://www.automotivelightingusa.com...6d35776e69fac4
edit: ^^^ actually they're only 55W, although the package says 85W in big font. Look at the number stamped on the base of the bulbs...
That's "virtual light output" and it means exactly shit. The only thing that matters is the electrical load the bulbs draw. If it's 55W, they'll work just fine. They may run slightly warmer due to the coating blocking some of the light and dissipating it as heat, but I doubt it would be much. It hasn't been a problem for me with the Nokyas.
Hey guys,
What is the best way to remove the stock factor fog lights? So I can replace the bulb? I have the print out and I see a bolt type screw underneath the bumber. However, the screw that I have to remove on the side seems like a real pain to get to. I can't really see it and I am afraid if I try and remove it I will have a difficult time screwing it back on. Any ideas?
Thanks!
-Eric
Thanks!
-Eric
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
we just have similar tastes (jdm
