Exhaust tip w/ bodykit
I was looking at the instruction for the rear bodykit, and it indicated that the stock exhaust tip is to be removed and replaced with a different one. I thought they were the same. Do i need a replacement one if i were to install the rear skirt?
on a somewhat related note, if you do remove the tips make sure you use a lot of wd40 or something to remove the rust (assuming there will be some) from the nut holding the tip on.
Originally Posted by JTso
The extended tips are also there to prevent melting of the exhaust opening of the lower spoiler.
Can someone WITH the OEM kit and WITH the longer tips please let me know some kind of measurement as to how far in/ot the end of the tip is supposed to be in relation to the bumper?
Reason I ask is because I just bough tmy PWP TSX (2004) and had them put a kit on. Since it didnt come from the factory as such, I'm afraid they might JUST put the kit itself on and not put the new exhaust tips on. I want to be sure they do so and measurements will definately help this cause.
Thanks!
~Eric
VIN 00032
Originally Posted by BallsOfSteel
You dont really have to remove the stock tips if you dont want to but the replacement tips are about an 1 inch longer to support the look of the body kit. The replacement tips comes with the rear body kit so you dont have to worry about ordering replacements at all.
Anyone else actually compare the two?
Originally Posted by ryanhook
Actually, I discovered after installing my kit that the replacement tips were the same length and diameter as the stock ones I removed. I had figured they would be longer, but nope.
Originally Posted by LannyM
The only difference is the placement of the mounting ring inside the tip. The tip for the body kit has the ring 1/2" closer to the the rear of the tip, effectively moving the tip outward by 1/2" so it sits flush with the lip.
So if it's not moved, I can move it myself w/ no problem?
This is the stock one-the ring is right on the edge on the new one.....
No, that ring is welded inside the tip. And it's split open from there back...........
So, if I bought the bodykit from Acura and said "install this", they technically HAVE to put the longer tips on, right? Anyone know if the long tips come part-and-parcel with the underbody/aero kit (not getting the trunk spoiler, just the skirts).??
The car is used, being bought from the dealer. The least I'd expect would be new tips to go with the bodykit, but, I want to know for sure so that when I pick it up I don't have any surprises.
Anyone know the measurement of the end of the tip, to a fixed point on the bodykit? If it's less, then I will be asking for new tips.
Thanks!
~Eric
I don't think you should. This is talking about the OEM exaust tip. They had to make it stick out further with the OEM body kit, otherwise it would look funny, so there's another tip replacement for the OEM bodykit.
Originally Posted by RMATIC09
IM not quite follownig this, if i have an aftermarket exhaust (fujitsubo) am i going to have trouble installing my OEM kit?
The Fuji seems to stick out a little more than the stock exhaust, so it should be great with the OEM kit.
nice, good news...becuase my exhaust seems to hang a bit, wonder if this will cover it up...anyone got any pics of fuji exhaust w/ oem kit?
Originally Posted by mg7726
rmatic did you get your oem kit yet? i'm tired of looking at your nice car w/o it
nope still waiting for another paycheck (im in the mortage business, have a deal closing soon,) , waiting for that check before i go and get it...
(plus some headers )
Ill post pics as soon as i have it...
08_UA7_Gr33k
02-11-2016 02:17 PM
joflewbyu2
10-08-2015 11:16 AM
08_UA7_Gr33k
09-27-2015 01:56 PM
