dzuy's impression of tein flex.
Old Jan 4, 2005 | 04:43 PM
  #41
cmf's Avatar
cmf
ATCer
You seem to be adjusting your suspension quite a bit, part of what might be causing rubbing is improper alignment. Have you done an alignment after making adjustments? Toe in or out could cause rubbing, especially with so much of a drop. I know when I had mine lowered at first, my rear wheels almost appeared to be turned out too much. I think it was off by almost two degrees from factory specs. Just something to keep in mind.
Old Jan 4, 2005 | 08:39 PM
  #42
dzuy's Avatar
Troutslap Mod-DUH-rator
i want to raise it first. i know it's too low.
alignment will come after i get the height i want.
Old Jan 4, 2005 | 08:41 PM
  #43
jmathew34's Avatar
i love slapping trouts on myself.
Old Jan 4, 2005 | 10:09 PM
  #44
dzuy's Avatar
Originally Posted by jmathew34
i like monkey balls!
Old Jan 12, 2005 | 09:05 PM
  #45
eviljohn's Avatar
revo evom / move over
i tried your instruction on the seats, i'm stuck after folding down the seats.
help
cuz i thought if it was that easy to adjust the settings, iam going to sell my EDFC>
please help me and give me some details, hopefully with pics.
Old Jan 12, 2005 | 10:53 PM
  #46
JTso's Avatar
You can't just slide the side up. There is a bolt which you have to remove first. Here is one way to do it... but reinstalling the seat bottom is slightly more difficult than if you also removed the fold-down seat backs.
1. Get in the back seat (the driver's side).
2. Reach behind the seat belt buckle and look for a 10mm bolt.
3. Use a long socket extension and remove the 10mm bolt.
4. Remove the rear seat bottom by lifting the left and right corner (one side at a time). You will hear a pop.
5. Remove the bolt to the side bolster.
6. Fold down the rear seat.
7. Slide the side bolster up. It has two latch points.
8. You should be able to access the adjustment at this point.
Old Jan 13, 2005 | 07:59 AM
  #47
dzuy's Avatar
ooo thanks man, i forgot i left that bolt off for easy access. the sides of the seat doesn't move, so i left it off.
oops. i forgot. thanks jtso!
Old Jan 13, 2005 | 08:24 AM
  #48
eviljohn's Avatar
thanx alot guys
mlody
Dec 4, 2019 02:11 PM
lanechanger
Oct 13, 2015 10:56 AM
ceb
ILX
Sep 27, 2015 10:56 AM
jmaxima03
Sep 27, 2015 10:22 AM
4drviper
Sep 23, 2015 07:42 PM
