Dakota Digital SGI-5 C settings
Old Nov 17, 2012 | 02:23 PM
dinoc's Avatar
Hi guys,
For those who used this module, please post your settings used for Dakota Digital SGI-5 C in order to fix your speedo (for those with custom transmission).
- year of the car , what transmission parts
- What switches did you use , what Input and what Output.
Old Nov 18, 2012 | 06:44 AM
dinoc's Avatar
So I did my final drive swap from 4.3 to 4.7.
The speedometer was off but the cruise control worked fine.
Then I used Dakota Digital SGi-5 C, to correct the speed .
It did correct it now the speed shown is the correct one.
But the cruise control stopped working after correcting the speedo.
Later I've managed to make the cruise control working after a lot of testings (tried different Outputs - it seems the speedo works with Option 1 and Option 2 , but with Option 3 and Option 4 is not working at all).
So I've put it back to Option 2 and switches back to
1-ON,2-OFF,3-ON,4-OFF
So I've managed to make the cruise control working again, after playing with the UP button , then readjusted the speed close to the same error range like OEM (for instant 100 km/h on the tachometer is like 96 km/h on GPS)
I still have some unclear issues:
1.) I've found adjusting the speed with UP and DOWN buttons is very very difficult - if I press shortly the DOWN button it looks like nothing happens you have to keep press the DOWN button for longer time .
How do you adjust your module ?
And if I keep press the DOWN button too long , the speed suddenly will drop to 0 speed - and the green led from the Dakota module goes off - and I need to restart the engine in order to have it working again - why is that ?
2). After restarting the engine there is 1 minute or 2 when the cruise control cannot be set, but after this period setting the cruise control to a certain speed works fine . Is this normal ?
gatrhumpy
19
Dec 31, 2015 04:22 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
dirleton
Sep 25, 2015 12:25 AM
2ManyHobbies
Sep 24, 2015 09:23 PM
