Cusco FSTB adjustibility?
So I just recieved my Cusco FSTB from Mr. HeelToe and while I was checking the package I notice that the plates are conneted to the bar with a bolt, the bar isn't one solid piece. So I was wondering if this bolt will need to be tighten up over time as it will be facing some stress. I was actually able to move the plate around a bit, is this normal for the Cusco FSTB?
I had the same question as you when I installed the bar. You will have to loosen the hex key bolt in order for the bar to fit. The easiest way was to just loosen each side and screw the blue plates on first. Then tighten the hex key after you have the plates secured. I'm pretty sure you wont have to re tighten these bolts
Also, am I suppose to tighten the hex screw (although I don't even know if it's possible) to a certain torque specs. I know that the 3 bolts on the plates are suppose to.
Former Sponsor
That bolt will not come loose over time.....I would not worry about it Like the others said, the 3 piece design makes installation easier, and that bolt is not tightened from the factory.
Originally Posted by 925tsx
what do the cusco chassis braces do?
