View Poll Results: Comptech SC or Turbo?
Comptech super charger
63.16%
Turbo charger
36.84%
Voters: 19. You may not vote on this poll
Comptech Super Charger or Turbo?
Old 05-29-2008 | 12:02 PM
Impulse05's Avatar
M3 Track Record
I have an '05 TSX and for a while I have been looking at the Comptech SC available for it. Everywhere I go people tell me turbo is more conventional for a Japanese car and will work/run better. I know as well as many other TSX owners that the car could use more low-end power and having that constant boost from the SC could be awesome but its 50HP at the wheels on a stock engine. If I change the engines parts [basically beef it up] would I be able to get more power out of the comptech SC? On the side of a turbo, they have the ability to give more of a boost than the SC but its a shot of boost not constant. And of course who doesn't like to hear the sound of a blow-off valve, its spine tingling If anyone has or has seen the Comptech SC in action or just knows which is a better choice the SC or the turbo I would greatly appreciate some feedback, Thank You!
Old 05-29-2008 | 12:24 PM
TheDukeZip's Avatar
I'm not sure where you plan on getting your turbo unless you plan on running RSX K-Pro with no gauges, cruise control, etc, etc... I would do a little research on these forums if I were you.
Old 05-29-2008 | 12:38 PM
Impulse05's Avatar
M3 Track Record
there are tons of turbos i can get im not so much worried about getting a turbo as i am getting it tuned and the over all performance im going to get out of it.
Old 05-29-2008 | 12:40 PM
clee109's Avatar
I Quit
Yes there are alot of turbos out there but none work with the TSX because of DBW, the only way to run a turbo is with a Kpro, RSX ecu, and the TSX ecu running at the same time and I haven't seen it done with my own eyes.
Comptech has worked with Hondata to build a supercharger solution complete with an ECU reflash for the TSX, so for now your only option is the CT supercharger for FI on the TSX
Old 05-29-2008 | 01:20 PM
shmork53's Avatar
Go with the SC. There is guy on here who just crushed the fuel pump regulator more (you have to do that anyway with the SC install) and put on a bigger pulley and got some impressive horsepower numbers. comptech has done all the hard work for you, with a turbo you have to do that work and there is no engine management. try searching for the thread.
Old 05-29-2008 | 01:23 PM
jmathew34's Avatar
try both at the same time
Old 05-29-2008 | 01:32 PM
Impulse05's Avatar
M3 Track Record
haha genious!! ill super charge a turbo to make an ultra super turbo charger! lol :P that would be nuts if there was a way to do both
Old 05-29-2008 | 01:58 PM
mdkxtreme's Avatar
im sorry if this is a little off topic, but i think its better to post it here than make a new thread. whats the difference between a supercharger and a turbo? which has more gains on hp and torque? i guess this is just a little food for thought for me
Old 05-29-2008 | 01:59 PM
925tsx's Avatar
B A N N E D
your only real option is S/C
and if you hae an auto, forget it unless you want to swap ecus with 04
Old 05-29-2008 | 02:08 PM
DAYTA's Avatar
Ummm...there IS a way to use both - it's called a twincharger.
The main advantage with a twincharger is that one form of induction negates the other's weakness. In other words, the supercharger provides boost in the lower RPMs when the turbo is still spooling up, and in turn the turbocharger provides boost in the upper RPMs without the parasitic loss that is associated with a supercharger.
Back to the original question, there is NO turbo currently that will function properly on a TSX without the loss of gauges and other amenities (HVAC, VSA, etc). The only reasonable option available to us right now is the CT Supercharger. However, since you have a 2005, is it AT or MT? If it's AT, the only way you can run a CT supercharger is to do an ECU swap with a 2004.
Old 05-29-2008 | 04:51 PM
ThirdLane's Avatar
Yeah there are many turbos out there. If you T/C your TSX, you won't have any engine management solution that will retain the guages, climate control, VSA, Cruise, etc. Plus you're looking at a lot of fab work for the manifold. CT supercharger is the only way to go
Old 05-29-2008 | 05:26 PM
mdkxtreme's Avatar
why is everyone ignoring me....
Old 05-29-2008 | 05:43 PM
LukeaTron's Avatar
A turbo collects waste energy (heat and pressure) from the exhaust and uses it drive an impeller on the intake side which forces air into the manifold. A super charger runs off a belt that is connected to the crank shaft. The belt turns a positive pressure helical compressor (most commonly) which in turn forces air into the manifold.
See wikipedia or howstuffworks.com for more in depth info. The reason people are ignoring you is because there is an ass ton of information on this topic that is extremely easy to find on your own.
Old 05-30-2008 | 12:57 AM
mdkxtreme's Avatar
oooh, google, never heard of it. any ways, thanks for not ignoring me :P
Old 05-30-2008 | 08:38 AM
Impulse05's Avatar
M3 Track Record
I thought the CT Supercharger came with an ecu specifically for it .. regardless what is so different about an '04 ecu that allows the SC to work with the AT and not the '05's AT? and do you think there would be a way to re-tune my '05's ecu so that it works like the '04's or just works with the SC if my only option [in terms of ecus] is to swap?
Old 05-30-2008 | 08:54 AM
ThirdLane's Avatar
CT SC comes with a reflash not a ecu. An 05 AT ecu is different than the 04. So unless you swap to an 04 ecu, you're SOL
Old 05-30-2008 | 10:03 AM
northbridge's Avatar
on to a CRZ
the 05 AT ECU cannot be reflashed due to a problem with the VIN. I wanted to have mine reflashed... Some helpful azine members explained why it wont work
The Comptech SC wont work without the re flash.
Old 05-30-2008 | 10:20 AM
PrecyseStylez's Avatar
Special-K
get an 04 ecu and run the supercharger.. your best and for now ONLY bet!
Old 05-30-2008 | 10:47 AM
DAYTA's Avatar
You also have to get the matching immobilizer with the ECU if you do end up going through with the swap.
IIRC, I believe it costs around $5-600 for a used 04 ECU/immobilizer, so ultimately you'd have to tack that onto your total price for the S/C.
Old 05-30-2008 | 04:39 PM
tdottsx's Avatar
will the super work on a 2006 auto?
Old 05-30-2008 | 05:07 PM
DAYTA's Avatar
because there is currently no S/C-specific reflash for the 06 AT (although there is a standard reflash).
Old 05-30-2008 | 05:24 PM
tdottsx's Avatar
any word of them ever making a reflash for it?probably not, i would assume.
Old 06-02-2008 | 08:53 AM
Impulse05's Avatar
M3 Track Record
one of my buddy's fathers owns an Acura dealership and one of the sales reps there cought word of Acura discontinuing the CSX and bringing in a TSX type-S he told me it may be realeased in a few months or next year. One of the thoughts was Acura was going to give it a similar engine if not the same engine as the RDX with that nice little turbo it has. He doesn't seem to think they will go that was because of cost. They will probably just drop a V6 in there oppose to a 4 banger turbo engine. Now this is just "hear-say" but that would be pretty awesome!!
Old 06-02-2008 | 09:56 AM
LukeaTron's Avatar
Welcome to the last 12 months of the rumor mill.
Old 06-02-2008 | 01:24 PM
DAYTA's Avatar
Based on the fact that the 07-08 guys most likely aren't ever going to see a standard reflash, I'd say the chances of Hondata coming out with a S/C-specific reflash for the 06 AT are slim to none.
Old 06-02-2008 | 01:31 PM
Impulse05's Avatar
M3 Track Record
I wonder, would it be possibly to drop an RDX engine in a TSX because they are roughtly the same size and just "upgrade" the turbo on that engine. [and obviously re-tune a few things] just a random thought .. the question is "hypothetically" could it be done?
Old 06-02-2008 | 03:05 PM
LukeaTron's Avatar
The RDX engine needs a lot more room for the turbo plumbing. Then there's the issue of the transmission which is obviously AWD for the RDX that would not work at all on the TSX. You'd probably need to use an RDX instrument cluster or be wicked good at hacking electronics on top of all that.
In short, to get that motor into a TSX would mean a car that is not at all a TSX anymore. It would be very Frankenstein.
Old 06-02-2008 | 07:25 PM
aaronng's Avatar
Driver/Detailer
I've seen a K20A+Kpro+patch harness+K24A ecu work. You lose the immobiliser function and VSA.
Old 06-02-2008 | 07:29 PM
Impulse05's Avatar
M3 Track Record
Im pretty new to all this .. what exactly is a K20A+Kpro+patch harness+K24A and what does reflash mean. yeah most people would probably slap their heads to that question but everyone has to ask and learn at one point.
ITSJESTER
17
12-06-2018 02:29 AM
CL-S progression 01
01-26-2016 04:15 PM
navtool.com
Sponsored Sales & Group Buys
87
01-23-2016 01:25 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
Quick Reply: Comptech Super Charger or Turbo?
