Comptech S/C - Partial throttle issues
Old May 4, 2009 | 06:40 AM
Audioserf's Avatar
boost owns
If you saw my other thread (Dyno Disappointment), you'd know I was getting a constant P0325 - Knock Sensor CEL. Well, I had a new knock sensor put in at Excelerate on Saturday, and that took care of those codes. Looks like it was a bad sensor after all.
However, I'm not out of the woods yet. The car pulls hard and wants to run - as long as I'm going WOT through the gears. If I'm riding partial throttle in boost (say 5500-6000rpm, particularly in 3rd and 4th gear), I get a flashing CEL. The Excelerate crew thought this was misfire caused by bad gas. I ran the gas tank out and refilled with Sunoco Ultra93, and I'm still having the issue.
Am I getting misfire? Since it's a flashing CEL, I don't know what the code is (it's not storing), but it's only coming on at partial throttle while in boost. When this happens, the car gets VERY jerky, ie if I lift off the pedal, the car lurches forward a bit.
Since this is only happening at part throttle I'm assuming it's a fuel issue... but if that's the case I'm not sure what can be done about it given I'm running the Hondata S/C Reflash, and nothing's been specifically tuned on our end. Could I have been given a bum Comptech ACM (since I understand that controls boost, fuel, and the MAP sensor)?
Other relevant mods:
Injen CAI
Topspeed header
RT Cat
Tanabe Catback
Things we've checked:
belt tension
sparkplugs
fuel
knock sensor
HELP!
- Matt, sick of the nightmare that has been his boost experience thus far.
Old May 5, 2009 | 11:54 PM
04-6mt-atx's Avatar
talk w/ the the guys @ Hondata, they are a wealth of knowledge
Old May 6, 2009 | 06:30 PM
Audioserf's Avatar
boost owns
Haven't seen a CEL in a couple days. Car seems to be running well. I'll be back on the dyno on Friday afternoon, hoping to lay down around 240whp/180wtq. If I'm significantly off from those figures, I'll be on the horn to Excelerate, CT Engineering, and Hondata -- all at once. :-p
Old May 6, 2009 | 11:41 PM
04-6mt-atx's Avatar
I understand why
cycdaniel
Dec 17, 2019 10:58 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Oakes
Wash & Wax
Nov 12, 2015 09:34 PM
k6biv
Sep 22, 2015 02:06 PM
Kevin Sami
Sep 22, 2015 09:59 AM
