Comptech or Hawk pads for my brake upgrade?
Probably gonna go with Powerslot rotors front and rear and the Comptech stainless line kit.
Should i go with the Comptech Metal Master pads or Hawk HPS or Hawk Performance Ceramic?
My car is a daily driver and i'm a fairly normal driver although i do some spirited driving on occasion. No track use whatsoever...
C'mon, man! Row yer own.
My
, I'd go with Hawk Ceramic. I think they're even lower dust than the OEM. Non-ceramic pads, I think, will dust quite a bit. For everyday driving, even spirited, I would think the better braking with non-ceramic wouldn't justify the heavier dust.
I still have my OEM's on, though, so that's just conjecture.
Thanks for the heads up on the ss lines. I'm split between the Hawk ceramics and the HPS now. I had the HPS on my old 240sx and liked them so i may as well go with them again.
yeah i did a search last night and read most of the reviews and i plan to get the motul brake fluid as well.
Originally Posted by moda_way
As an FYI, I know Motul works and other has DOT 4 stuff in their systems, I don't think our system is specified for DOT 5.1 which is what Motul is. Just be careful because I'm not sure how the seals and such will handle that formulation. The DOT 3 Acura fluid is plenty good. Basically, if you do run into leaking seals or something, I doubt Acura would warranty it b/c of the fluid change. Motul is great stuff, but you might want to put it in after warranty is up.
Motul may ruin your ABS modulator, so if you do use Motul, disable the ABS by pulling the fuse out.
My
The only thing that's stopped me from ordering the Hawk Ceramic pads is online reviews I've read that say they dust just as much as the HPS do. I'm really in the market for a low-dust pad. Can anyone say otherwise about the Hawk Ceramic or point to another good brand for low dust, every day driving pads?
Originally Posted by KingTSX
Will pulling the fuse disable anything else??? Besides the ABS brake setup? I for one got the Hawk HPS pads and am putting them on with rotoras ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Please don't forget VSA and ABS are critical safety features.
SidhuSaaB
05-30-2020 12:40 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
