clutches
Old Dec 17, 2004 | 09:21 AM
AZTSX's Avatar
clutches
I was wondering what clutch kit would work with our tsx because when/if either a turbocharger or supercharger comes out we are going to need a new one and since i have almost 60k miles on my car (will have a lot more by the time FI comes out) I would be interested in knowing what clutch application matches ours
Old Dec 17, 2004 | 09:28 AM
biker's Avatar
I'd venture to guess the regular clutch would be good enough for most applications. Once you get to the point that you need a clutch upgrade other parts of the drive train will need upgrades too.
Old Dec 17, 2004 | 09:35 AM
AZTSX's Avatar
But lets say i wanted to have 300-350whp would the stock clutch be suffcient especially since it is at about 60k miles?
Old Dec 17, 2004 | 09:47 AM
Dan Martin's Avatar
Photography Nerd
You're going to want to upgrade that clutch. I'm pretty sure the clutch is the same as for the RSX but I think we'll need a guru to confirm that.
Paging Dr. JTso ....
Old Dec 17, 2004 | 10:02 AM
cmf's Avatar
cmf
ATCer
I know this may not help much, but I have seen that info someplace. I think it was in the most recent issue of Honda Tuning if someone has it. It mentioned the trannys of the Accord, RSX, TSX, and a few others. If it wasn't there, it was a link someone provided from TOV.
Old Dec 17, 2004 | 10:17 AM
biker's Avatar
At 350whp you'll be wearing other things out in a hurry too.
If you have 60K miles on your car now, you're probably the kind of person that will probably get 200K+ miles out of it cause I'd guess most of those are highway miles. Heck you're almost on pace with the sauceman.
Old Dec 17, 2004 | 02:45 PM
AZTSX's Avatar
ya a lot of road trips with the family not to mention i go to work and i go to a north and main campus of a JC also i have to work my "other" job at my family's assisted living home 20 miles away so i do A LOT of driving
Also biker sorry i am a noob to this what other parts of the drivetrain will i need to replace?
Old Dec 17, 2004 | 03:43 PM
sauceman's Avatar
Moderator Alumnus
You bet!
AZTSX, since when do you have your TSX?
Old Dec 17, 2004 | 06:23 PM
AZTSX's Avatar
since may 2003
Old Dec 17, 2004 | 07:49 PM
PixelHarmony's Avatar
Master Graphic Artist
Yeah, you'll definately need a new clutch for FI. I believe there isn't a aftermarket clutch out for our car yet that can handle over 300whp... that's why the DAZZ doesn't push that much past stock clutch capabilities.
I know for my friends love Exedy clutches. If they ever came out with a racing clutch for the TSX I'll be down to get it.
http://www.coximport.com/exedy/
Check it out for more info. They have an RSX application, but nothing for the TSX yet..
Old Dec 18, 2004 | 10:30 AM
AZTSX's Avatar
thats what i am trying to figure out. If the RSX applications work with the TSX JTso any idea? cmf figure out the link? THANKS Guys i am jst getting ready for FI cause once its out im all over it!
Old Dec 18, 2004 | 10:41 AM
JTso's Avatar
Hmm... I'm not sure about this one. The quickest way to find out might be going down to the Acura parts counter and ask to pull both clutch sets and compare.
Old Dec 18, 2004 | 10:50 AM
biker's Avatar
I'm not sure the tranny and diff is meant to take 350HP. Also, the internals of the engine were probably not designed with FI in mind. To jump from 200 to 350HP is asking a lot of standard engine components. Sure none of the parts will blow up on the first or second launch but the life of all of these components will be a lot shorter when you put 350HP to the ground vs. 200.
I mean look at the Mazdaspeed6 - that has "only" 275HP but they beefed up just about everything on the car and added AWD to handle the extra HP.
Old Dec 18, 2004 | 10:55 AM
Dan Martin's Avatar
Photography Nerd
The RSX is probably the best place to turn for comparison since it's been on the market for much longer and there are many people running high boost applications for a while. So far I haven't heard of anything breaking other than clutches wearing out.
Old Dec 18, 2004 | 10:58 AM
cmf's Avatar
cmf
ATCer
I think anywhere outside of a stage 1 kit will require a few internals be replaced. I'm think 350WHP is gonna be higher than a stage 1. You're talking almost double the horsepower.
Old Dec 18, 2004 | 10:59 AM
AZTSX's Avatar
ya ive been over at clubRSX and Ive been doing alot of reading(maybe not enough) so far the only problem i see is of course premature clutch wear.
Old Dec 18, 2004 | 11:00 AM
kurt_bradley's Avatar
Same clutch as an RSX-S (2002-2004 models). I don't have the catalog for the 2005 RSX. In other words, you could install an Exedy Cerametallic clutch and fly combo in there.
Old Dec 18, 2004 | 11:03 AM
Dan Martin's Avatar
Photography Nerd
Old Dec 18, 2004 | 12:04 PM
AZTSX's Avatar
Thanks alot kurt!
Old Dec 18, 2004 | 01:00 PM
JTso's Avatar
Good info Kurt!
Old Dec 18, 2004 | 03:36 PM
Thanks. Then again...I did try to figure just how much I could play with between the RSX-S and the TSX.
Old Dec 21, 2004 | 02:24 AM
In the SSC magazine article the HKS guy said that they ran 15psi of boost with stock internals on the TSX. However they mentioned in the Import Tuner Magazine that the clutch did need to be replaced to handle all that HP. I'd assume anywhere from 230-275WHP is safe on internals and stock clutch for the TSX.
Now we'll just wait for someone to buy the Comptech Supercharger Who's in line to buy that beast?
Old Dec 21, 2004 | 11:43 AM
NightHawk CL9's Avatar
WAS HONDATAFIED IN
that was a question that had me thinking for a while..... thanks for the answer
Old Dec 21, 2004 | 07:43 PM
K20AHonda's Avatar
Clutch Masters clutch is very reliable. We have tested there stage 3 from 200hp all motor to 450 boosting. Very good clutch and long lasting.
Old Dec 22, 2004 | 04:43 PM
AZTSX's Avatar
So all aftermarket clutch kits for the RSX-S will be compatible with the TSX. So we can choose from clutchmasters,ACT, exedy, etc...
Old Dec 22, 2004 | 04:45 PM
Yessir.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
knight rider
Mar 4, 2016 08:59 AM
MilanoRedDashR
Sep 24, 2015 11:04 PM
