Check Engine 3 times after RT Cat
Old Aug 27, 2006 | 09:47 PM
kendroz's Avatar
Greetings!!
Since my RT Cat a month ago, I been resetting the ECU (disconnecting the battery) because of the check engine ligth. The strange thing is that it turns on when driving at slow speed (before 60 mphs). I'am tired of disconnecting the battery and resetting my radio unit.
Any suggestions ??
I also hear some sounds ( like air escaping ) from the cat but my mechanic saids that is normal.
Thanks to all in advance
Old Aug 27, 2006 | 11:57 PM
aaronng's Avatar
Driver/Detailer
Pull the error code from your car.
Old Aug 28, 2006 | 12:01 AM
Tsx536's Avatar
Rep'n Taxbrain.com
Yeah, This is common with the RT cat. Pull the code like Aaron said, but I'm guess it's P0135 - Catalytic convertor ineffeciency
Anyway, the solution is to put an anti fouler on the o2 sensor. Do a search and you'll see what I'm talking about.
You can also get a Brockway R920 to clear the code anytime it comes. This unit does a lot more than clear CELs, but it also costs alot more than an anti fouler.
NJALLDAY57
Oct 13, 2015 08:25 AM
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
