Can't get ECU out for Hondata
How did you guys disconnect the 4 wire plugs from the ECU and slide it out?? It's like impossible. I know about the tab in the middle but I just can't seem to get a good grip to pull the plugs out. Any tips on removing the ECU?
Ticket Slow Drivers
I just did this last week. Disconnect the harness from the ECU, while the ECU is still mounted - better leverage. Push the clip down and pull...they will come out. You can pull on the wires, but you don't have to be rough. Also, it is a tight fit to get the ECU out, but it will go!
I found the hardest part was maneuvering the lower steering column shroud out of the way to remove the immobilizer.
Good Luck!
Good Luck!
^^do you guys have an alternate solution at least? Run an 06 ECU?
where is my garage?!
1 Post
1 Post
dammit, i missed the edit window.
here is the thread/post in question where tsx wisconsin badger mentioned he called hondata and they advised against the 06/07 ecu swap. see post #25 at the bottom.
THREAD
THREAD
Originally Posted by DjElucid
So how long did it take to remove and re-install? The shop is willing to do it for $80, should I go with that option?
Absolutely, just pay them the money already.
cycdaniel
12-17-2019 10:58 AM
mrkingstonvi
02-22-2016 01:53 PM
