CAI vs SRI
CAI vs SRI
Hi, this is my first time posting. I just purchased a `05 black TSX. I would like to begin to make a few mods and I thought that I would start with the intake.
My question is, which intake should I go with. What intakes have the best low end gains and which have the best high end gains. I do a lot of highway driving but I enjoy getting on the gas a little as well.
Any recommendations?
SRI - gives you low end gain not as much total horsepower increase. it also makes throttle response a little bit.
CAI - gives you more high end gain and the higest total horsepower gain for an intake. it actually takes a little away from the low end to but not much.
my recommendation is either a injen intake or a k&n intake. both can be used as a SRI or CAI as they are a two pipe construction. however they do make the car a little noiser at WOT (Wide Open Throttle).
Your other option is a comptech ice box with is a CAI by design that has a airbox kinda like the stock intake design. it does not create as much power as the injen or the k&n but it cause alittle less noise.
Originally Posted by ToRoNTo_9
How much time does it take to switch between a CAI and a SRI? Do I have to take the intake apart?
here are some pictures of my injen in SRI and CAI. and then a picture with the bumper off showing where the filter goes in CAI mode.
thanks for the pics and the info...it is much appreciated. Is it difficult to remove the front bumper
Try a search, this has been covered many times and there is much information on it.
Hey toronot_9 <-- I hope ya "9" does not has any special meaning.... haha
anyways, I'm from Toronto too, and I have got the Injen CAI too. Don't worry about the weather because my car survive thru the winter snowing and summer rainning, no hydrolocking whatsoever. Installation might be a bitch if you have not work on any car before. I took my car to install the CAI, Header, High-flow Cat.............. etc @ a shop.
Also, which is better the SP or RD
Once you have removed the resonator, any changes from SRI to CAI can be done through the wheelwell liner. You don't need to remove you bumper a 2nd time.
Former Sponsor
Injen SP1431 intake and the Injen RD1430
Originally Posted by afici0nad0
removing the front bumper was very easy for me. no jack and jack-stands needed. 30min max to remove the front bumper.
as long as your car is stock height. I have to jack mine up since the front lip is less than 2 inches from the ground.
lanechanger
Oct 13, 2015 10:56 AM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
