Bumper Removal
Old Oct 25, 2006 | 02:55 AM
FiVa's Avatar
Bumper Removal
Hi guys!
I am trying to get the resonator off to install the Icebox.
I ve got all the clips, screw, etc off and I basically got 3/4 of the bumper off (those hooks from the 2 side (from the fender) off and the pessanger side (under headlight) off), but i just can't those honks off the driver side headlight.
Anybody has any tips? I tried to pull hard, but I afraid i will break the bumper
Any help is appreciated guys!
Old Oct 25, 2006 | 06:49 AM
moda_way's Avatar
I assume you mean honks = hooks
Are you talking 04/05 or 06 TSX?
If you want to get the full details for an 04/05, go to HandA-accessories.com and check out the instructions for the Fog Light installation.
Old Oct 25, 2006 | 01:02 PM
FiVa's Avatar
Yeah sorry HOOKS haha
I am talking about a 2005 TSX.
And yes i followed the fog light installation manual, but i just cannot get those hooks off under the driver side's headlight.
Old Oct 25, 2006 | 01:06 PM
moda_way's Avatar
Assuming you removed the screw from the wheel well, give the bumper a slightly push up on the wheel well side and pull out.
Old Oct 25, 2006 | 02:14 PM
ILoveMyHonda's Avatar
17781708
yeah, if you have all the required screws and clips off, just grab the corner edge of the bumper in the wheel well and pull towards the front of the car.
It will pop right off.
Old Oct 25, 2006 | 07:31 PM
FiVa's Avatar
I basically pop the whole bumper off, its just that the bumper seems stuck on those hooks under the headlight.
I ll try againt tonight! Thanks guys
Old Oct 26, 2006 | 05:24 AM
moda_way's Avatar
Update?
Old Oct 27, 2006 | 04:26 AM
FiVa's Avatar
I successfully took the bumper off..it was actually quite easy
But i could not get the bolt off the resonator with my current tools, so I will probably get a ratchet to help remove them
Would something like this help? Cause the bolt is incredibly tight
or this?
http://canadiantire.ca/browse/produc...=1161941128253
Old Oct 27, 2006 | 05:48 AM
moda_way's Avatar
^^Yes, a set of sockets (Automotive Kit) and a couple of extensions will pay off. You don't need to worry about US (Standard) sockets unless you intend to work on other cars.
What ended up being the solution to getting your bumper off?
Old Oct 27, 2006 | 01:24 PM
FiVa's Avatar
I kind of kept "shaking" the bumper then i heard a few "clicks" and the bumper is off.
Its incredibly that now i can take off the bumper under 15 mins, but when i tried it the first time it took like an hour.
Thanks for your help man!
Old Oct 29, 2006 | 02:14 AM
FiVa's Avatar
I have one more question...How did you guys remove the bolt on the resonator on the wheel well side? There wasn't enough space, are there any special ways?
Old Oct 29, 2006 | 01:08 PM
kaliraver69's Avatar
Here is the link to the Injen CIA install with pix I think this will help you alot, good luck.
http://www.acura-tsx.com/forums/showthread.php?t=19067
Old Dec 2, 2007 | 06:03 PM
sluggercz's Avatar
whew, i just converted my Injen CAI into SR. took off the front bumper to do so and was much easier after getting the bumper off when compared to wheel-well way. Advice to future installers of the Injen Intake; go SR, the HP gains are about the same, you get more torque lower end, plus you can leave the resonator in (which is by far the hardest piece of hardware to get out of the car, not to mention put back in)
Jul 16, 2017 07:33 AM
BIGxRED
Oct 19, 2015 10:47 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
STL TL-S
Sep 23, 2015 08:52 PM
