is anyone planning to do a complete engine swap?
the 2.3L RSXs are making 300WHP with the K24 block wit modified heads...etc. link to the 2.3L RSX kit, which makes me think what is our car REALLY capable of.
I thought about changing the cams, pistons...etc. but it seems just a waste of money if our ECU cannot be altered to work with the mods. And the rsx-s pistons' bore is 1mm smaller which makes direct swap impossible.
finally, i come to the conclusion that maybe the easiest way is to swap out everything and put a DC5-R engine while keeping only the K24 block. (or a typeS engine). however, one last problem is the throttle will need to be replaced as well from drive by wire to mechanical. This also rises a problem coz our gas pedal is different from RSXs. (assuming i dont care about the rpm gauge, losing the VSC...etc).
so, my question is, does anyone know if the EuroR is also drive-by-wire? if so, the swap might not be as hard as i think. Or should i just forget about the idea and be content with what we got?
justin7779
12-25-2015 10:33 PM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
