7-speed SS AT Transmission
Is the 7-speed SS Auto Transmission available on some JDM Hondas already?
Can we swap that 7AT tranny into our TSX?
Does it fit? Does it work?
i know BMW has a 7 speed Paddle shift in research for the M6...but i havent heard of a honda app...I dont feel however that this would be a positive mod for our cars, we have no where near enough horsepower to run something like that, and would probibly be less agressive gearing, also would prob require less revs in each gear... TSX is only quick because of its high revving ability
Nope no link... Ive never heard of a Honda application, esp one available to the general public, even though it has no bennifit to our car, still wouldnt mind seeing how it works, Honda is very good at making a fun MT Transmission, and our SS aint half bad either, So this would probibly be a very interesting car to drive
But one step at a time. Honda/Acura needs a 6 speed auto first before they start doing 7 speed trannies.
Originally Posted by CGTSX2004
While I agree I haven't heard of a Honda application, I disagree on it not being a good match for the TSX. The 7 speed transmission would mean the gear ratios are spaced closer together, meaning the gear is actually more aggressive. And if it is a manual gearbox based transmission, there is no reason it couldn't rev to the current 7200 rpm redline. I think this gearbox would be a perfect match for the TSX's high revving engine and would probably improve acceleration times.
Im just thinking out loud here, but Could the 2.4 L engine of the TSX, handle that kinda transmission, 7 Gears revving up to 7200 rpms on each of them... Seems like more then enough to kill ur engine, BMW's having difficulty rigging the gears on a Hopped up V8, The 5AT's gearing is attcually pritty nice for the car too, First i feel is alittle short, but besides that its not bad at all, 100 mph in 3rd gear im not complaining... We should do more power based modifications, before we start fooling around w/ the Transmissions in a fashon like that
By inserting another gear, it effectively shortens the ratios on the first 6 gears. This has the same effect as dropping the gear ratios on a 6 speed car, except you're inserting another gear to compensate for it. The shorter gearing would also help in the acceleration times. Shorter gearing on low torque cars is a good way to effectively improve the torque being transferred to the wheels.
Baka Unco
I'm not following...
MB has their 7 speed GTronic AT trickling down to the E350 and other cars using the new 3.5L V6 drivetrain this year so a 7 speed AT will not be that rare anymore. There are some rare ATs in JDM world but I don't think any of those will get exported.
The problem is that once you get to about 6 gears you quicly approach the law of diminishing returns.
動力伝達・
走行装置 変速比 前進 2.367~0.407※4 - 2.367~0.407※4 - 2.367~0.407※4
7スピードモード時※5(7速オートシフトモード、7速マニュアルシフトモード)
または5速マニュアル 1速 2.152 3.142 2.152 3.142 2.152
2速 1.456 1.750 1.456 1.750 1.456
3速 1.119 1.241 1.119 1.241 1.119
4速 0.884 0.969 0.884 0.969 0.884
5速 0.719 0.756 0.719 0.756 0.719
6速 0.601 - 0.601 - 0.601
7速 0.524 - 0.524 - 0.524
後退 4.226~2.367 3.230 4.226~2.367 3.230 4.226~2.367
More details would be a CVT which run by a chain and it's out made October 2004.
Just wondering if there's any transmission mechanic in here? Is it easy to swap this transmission?
cos still honda to honda, 5AT auto 7AT CVT....... I think
anyway, the 7AT CVT will boost two things.
1. It's boosts the fuel consumption, better mileage than tiptronic.
2. It's boosts the acceleration, even faster manual transmission.
Data concept history from A4's CVT.
Photography Nerd
CVT's are very picky with the amount of power you can apply to them. It's hard to build them strong so you generally see them on low HP applications.
1. It's boosts the fuel consumption.
2. It's boosts the acceleration.
Photography Nerd
There's no reason why a CVT couldn't work with a TSX but retrofitting one wouldn't be easy. There's a major difference in computer controllers.
Actually since there's no predefined ratios with a CVT there's no reason why they couldn't make it an 8, 9 or 30 "gear" transmission.
I've never driven a CVT before (aside from a golf cart) but I'd be curious to see what it's like.
Originally Posted by micko
as i know....JDM Honda Fit and Civic already use 7-speed shift AT
The Honda UK site gives the following perfomance numbers for 0-100kph
Acceleration 0-62 mph (secs) 13.7 (1.2l 5sp) 13.3 (1.4l 5 sp) / 14.5 (CVT)
I'd venture to guess that when the Fit/Jazz makes it to the US the numbers will be similar. Can't wait for someone to take one to the track.
joflewbyu2
10-08-2015 11:16 AM
