2 Tanabe Coilovers out
Old Mar 16, 2005 | 11:27 PM
xizor's Avatar
Bye TSX, hello domestic?
Saw these on Ebay and on Tanabe's site link
Their TANABE PRO S-0C it out (link )
and TANABE PRO S-0C TYPE-II (link )
pretty good prices, anyone want to look and see what the difference between the regular and Type 2?
Old Mar 16, 2005 | 11:29 PM
Dan Martin's Avatar
Photography Nerd
@ $332.50 for shipping to Canada.
Old Mar 17, 2005 | 12:01 AM
Tsx536's Avatar
Rep'n Taxbrain.com
Dang....332 !! That's ....and I thought $95 for shipping in the US was high.
Old Mar 17, 2005 | 12:40 AM
BU's Avatar
BU
I purchased Tanabe PRO S-0C TYPE-II COILOVER KIT last August. Only Height Adjustable. Great for Daily Driving. Definitly not for any track.
If I am right. The only different will be Tanabe Pro S-OC have a extra "Helper Spring" on the top of the coilover. Notice in the picture, The 1 inch thinner purple spring... that's the different.
Old Mar 17, 2005 | 04:50 AM
LannyM's Avatar
Hondaholic
In the listing it says:
The exact same product and price with FREE GROUND SHIPPING can be found on our website at www.mach1car.com.
ebay doesn't allow listings like that, but it's kind of hard to police..........
Old Mar 17, 2005 | 12:13 PM
Tsx536's Avatar
Rep'n Taxbrain.com
What does this "helper spring" do?
Is it effective?
Old Mar 17, 2005 | 12:23 PM
jiggaman's Avatar
I spend 2 much time here
Is it effective?
yes, its very "helpful" haha
Old Mar 17, 2005 | 01:21 PM
LannyM's Avatar
Hondaholic
Is it effective?
Well, traditionally, a helper spring would take up the slack when the strut is fully extended; conceivably a short linear spring could fall out of its mounts on a really long extension, or when jacking the car up. It also could allow a softer initial impact, much like a progressive spring does.......
Old Mar 17, 2005 | 05:52 PM
JeffTSX's Avatar
Subie Tech
I've been eyeing them for a long time already....decisions decisions.
Old Mar 17, 2005 | 06:01 PM
rmpage's Avatar
Drives With Hands
Sweet. So what height did you set yours to, and how was the ride at that height as opposed to stock?
I'm looking for a progressive spring/shock combo to drop by about 1.5"/1" F/R
Old Mar 17, 2005 | 06:30 PM
Stokeless_TSX's Avatar
Stokeless
HAHA If you go to the links read all the way through. If you buy from the shops actual website there is no shipping costs. (in the US not sure bout you Canada folks)
Old Mar 17, 2005 | 06:40 PM
vwong's Avatar
n00b
The helper springs are basically all collapsed once the car is on the ground, so they won't make any difference. The main springs still do all the work. Other than preventing the main spring from the slop when the shock is fully extended, I don't know what else the helper springs do. The TEIN HA on my Prelude has the helper springs also.
Old Mar 17, 2005 | 07:00 PM
LannyM's Avatar
Hondaholic
Here's a quote from their product description:
Helper springs assist with rebound stability, ride comfort and keep the main coil spring seated. Preload of the main spring can also be set to zero, for maximum comfort and suspension travel.
Old Mar 17, 2005 | 07:02 PM
Stokeless
So wait the type II is only height adjustable not the dampening? What about the other one? Is it height and dampening adjustable?
Old Mar 17, 2005 | 07:13 PM
JeffTSX's Avatar
Subie Tech
What do you mean by that?
Old Mar 17, 2005 | 08:48 PM
LannyM's Avatar
Hondaholic
Neither unit is dampening adjustable; Tanabe makes the Pro S-S model which is, but no TSX application as of yet.
Spring rates on these units are not stiff enough for any type of serious track use; I can't think of any coilover for the TSX with softer springs........
Old Mar 17, 2005 | 09:05 PM
BU's Avatar
BU
Thank You for the answer, LannyM.
It is a soft & comfortable ride, but a still bit stiffer than Stock for better handling.
Old Mar 17, 2005 | 09:46 PM
rmpage's Avatar
Drives With Hands
So, would you say somewhat comparable to the A-spec then?
Old Mar 18, 2005 | 06:53 AM
LannyM's Avatar
Hondaholic
Spring rates for A-spec is around 300 lb/in Front and 155 lb/in rear. The Tanabes are around 450 front and 225 rear. Ride should be pretty reasonable with a setup like that.
One thing I'm not sure about-if the unit employs a solid pillowball mount or if it uses the factory top mount. A pillowball would be a little stiffer........
MrHeeltoe
20
Feb 23, 2023 01:54 PM
ttimberlak443
21
Oct 22, 2016 10:23 PM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
4drviper
Sep 23, 2015 07:42 PM
