06 MT reflash available in 1 week
The Hondata 06-TSX reflash for manual transmission is available from the 27th February.
We are looking for an auto 06 TSX for testing in Southern California. Contact Hondata and ask for Doug.
The 06 responds a little better than the 04 due to its improved breathing (cams, valves, exhaust, throttle body etc.) In stock form the 06 TSX reflash gains 32 hp at 6000 rpm compared to the 04/05 gaining about 24hp.
Full information here:
http://www.hondata.com/reflash_tsx_06.html
Picture here:
Before: 06 TSX with stock intake and header
After : 06 TSX Reflash with stock intake and header
Picture here:
Doug, in the information, you guys say that the 06 intake charge suffers some from the heat off the block and that one of the heat shield gaskets is recommended. Does the 04/05 heat shield gasket fit the 06 without issue? I still have the one I got from when I had my 04 AT reflash fixed and I'm wondering if I can install it.
Originally Posted by narci
Speaking of 05 AT, did Hondata abandon this group?
However, I've asked about the 05 5at in the other thread though, and got no answer. Any insight on this, Hondata?
Canuck
Originally Posted by CarbonGray Earl
That would suck if they do, but I doubt that's the case. If the SC is being made for the 05 ATs as well, we would need a reflash from hondata as well. Thus they would have to have the ECU cracked.
downside is if they can crack the 06 AT and the 05 AT is still different..then they just might abandon it.
I got a feeling they are going to work on the 06 AT first hoping that once they crack the 06, the 05 will be right behind just like how the 05MT and 06 MT 's are.
Someone stole "My Garage"
Originally Posted by Brandon24pdx
Hello? 05 5AT anyone?
Theres like 3x as many of them as there are 06 MT's
Canuck
Originally Posted by curls
Who buys a 5AT for performance?
http://www.acura-tsx.com/forums/showthread.php?t=28196
God bless you hondata people. Thanks for keeping us posted doug. When your 2006 AT reflash is available I will be in the front of the line.
So much for my new stereo system, that's gonna have to wait another month. $$.
Whatever. I’m shocked and chagrined, mortified and stupefied about no 05AT reflash.
We never said anywhere that we would not make an 05 AT reflash. What we did say that we would continue to try. However we are releasing reflashes in the order that we are capable.
One option we have for the 05 AT is to provide an 04 ECU with reflash for the 05 AT. That would of course be more expensive as it includes the ECU. I would expect a price of about $1250. You would retain your stock ECU and could sell the reflashed 04 ECU at a later time.
Originally Posted by Yui
Does this mean the Comptech Supercharger for the 2006 MT is not far away?
06 Performance changes
Here are two dynos demonstrating the performance changes of the 06 TSX.
The first compares a stock 04 TSX (dotted blue) to a stock 06 TSX (solid pink) .
The second compares:
Solid blue - 06 TSX with reflash
Dotted yellow - 04 TSX with reflash intake and headers
As you can see the changes to the 06 TSX are equivalent to the intake and headers on the 04 as long as both have a reflash.
Drives With Hands
Finally we get to see the concrete data regarding improvements to MY 2006. All that intake tract work seems to have got you guys a slightly lower VTEC point too.
Thanks for the update, Im still hoping you guys crack this ECU and still charge the same price everyone else is getting.
Is 05 MT reflash available with the ECU for sales? I am guessing that it would be around 1250 aslo.
My thoughts is to have 2 ECU - 1 hondata and 1 stock. and convert back to stock when i want to. like when i take my car for mod not friendly Acura dealer.
Wow...can those numbers be correct?
The 06 gained 20 hp over the 04/05 model!
This is going to be an interesting dyno tomorrow.
Not a significant difference between the 2 plots but the one hondata posted above seems to understate the 04 dyno ever so slightly after the VTEC point of 6000 rpm.
sho-one - Can you install just the cam?
- No. You need other breathing improvements to make the cam work - especially the exhaust improvements to reduce backpressure
CGTSX2004
Allowing for variations between cars I would predict a minimum of 15HP gain from a stock 04 to a stock 06.
Seems the stock 04 MT dyno above is lackluster (slightly) as compared to this one: http://www.hondata.com/images/dynots...vs-reflash.gif (purple/red is stock 04 MT dyno).
We are looking at the options here, but we need to do more testing. Can we have one ECU operate the 04, 05 and 06? For example will the 06 ECU work the 04 and 05?. Will the ECU work on overseas 200 hp K24 Accords?
I have 05 MT. I want to know if I can buy a 05 MT reflashed ECU without sending my stock ECU. i.e buying the actual ECU ( reflashed) and pop it in my car.
hondata
hondata. i have an 05 AT and an 04 AT ECU that i'm having synchronized to my Key. have y'all had any problems with 04 ecu's n- 05's,. The Comptech Supercharger will work as well wont it since there is no mechanical differ. expet the ECU.
Patrick
Patrick
Patrick
Patrick
The MT 05 ECU performed identically to the MT 04 ECU in our dyno tests. I would expect the same of the Auto.
Edit. From the previous post, it appears that someone has already tested that this works well.
Stokeless
Originally Posted by sho-one
can you put an 06 cam in an 04?
