04 SI - TSX K24 SWAP w/JR S/C + 6speed!!
It has the JRSC!!
Does that mean the JRSC is already out for the TSX??
The beast is puttin down 310hp/240tq to the wheels!!
V6Performance.net board:
http://www.v6performance.net/forums/...d=1#post608882
Direct Link to shop's website:
http://www.mrrocket.com/ep3.htm
Bye TSX, hello domestic?
Originally Posted by loxllxol
It has the JRSC!!
If you take out the TSX manifold, throttle body, DBW and ECU, you could use all the parts from the RSX JRSC which I'm 99% sure they did. RSX swaps I've seen just use RSX manifolds w/ slight modification to fit on the K24 block. Sorry to burst your bubble.
Originally Posted by xizor
...If you take out the TSX manifold, throttle body, DBW and ECU, you could use all the parts from the RSX JRSC which I'm 99% sure they did.
Originally Posted by moda_way
If you look at the bottom of this thread, you can easily see they are using the RSX S manifold. Ours sits much higher and you can plainly see there is no DBW throttle body.
Originally Posted by ignatiuslee
That Civic Si can have the RSX-S MT with our TSX engine. So does that mean we can swap our transmission with RSX-S's MT too?
Because I have an AT TSX, and I am thinking about to swap the transmission.
So I can get the one from RSX-S?
xsilverhawkx
09-28-2015 06:51 PM
STL TL-S
09-23-2015 08:52 PM
