04/06 Front end swap is possible
#82
17781708
Originally Posted by turoneatingpinoy
It's already been done . . .
![](http://img511.imageshack.us/img511/345/mugen06xj3.jpg)
nice "Type-R" badge and LED fogs
![Rice](https://acurazine.com/forums/images/smilies/rice.gif)
someone always finds a way to ruin perfectly good JDM parts
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
#83
Originally Posted by DC-CL9
Had I known this I would have bought an '04 front bumper, mugen grill and mugen lip...it flows so much better than my '06 bumper. Still may do it.
Nice work, guys!
#86
Nope, we really didn't know for sure that they were interchangeable, until now.
Also, no, the 06 fogs would not (easily) go into an older bumper, you would need custom housings for them.
#88
Originally Posted by kostantinos
i guess i'm the oddball
i have an 06 and want 05 jdm headlights lol
the only thing is i want lhd models so i dont have to mess with the projectors
anyone have a hookup to get them?
#90
Why would they all be rhd? what about the european countries which are lhd like the us?
how did reach do it? by opening the headlights? or is there an easier way?
thanks
kosta
thanks
kosta
#91
I spend 2 much time here
i changed out projectors as well, it is somewhat of a PITB but is doable. Using a magnetic screwdriver will definately help with putting it back together after making the swap. If you attempt this you will see what i mean. ALso removing the silica gel pack might make it easier too because it will give you more room to work with.
#92
You guys didn't have to open the housing correct? You had to take the projectors out through the back of the housing? Please explain since I will be getting some JDM headlights next month and will probably be attempting this mod myself.
#93
yes pull out the back, main challenge is that the one of the pieces you need to pull out is like a couple mm bigger than the hole. so you have to apply some pressure and angle it just right
#95
it didn't do any visual damage that you could see form the outside. just some minor scratches on plastic where the whole in the back is. if you are really good you could probably do it without making hardly a single scratch. i did the second one better then the first after i got the hang of it.
#102
Originally Posted by BillyTSX
actually, my question was the exact opposite, would the 04 rear lip kit and side skirts fit an 06??
For the last time, ALL parts are interchangeable, except 04/05 vs 06 specific FRONT LIP pieces only, due to the re-designed front fascia.
#103
Bye TSX, hello domestic?
Originally Posted by Reach
The rear lip wil fit actually. Both rears are the same as well.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
#105
is glad to be back!
#107
Originally Posted by EuRTSX
I believe the 06 Euro R fit K24A's 04 Conversion with modifications done to fit the 06 rear.
Originally Posted by MyK24a
My bumper is a 03 version, the bodykit shop had to custom a little bit to fit
the 06 rear lip
the 06 rear lip
basically some drilling of holes at the rear for fitting of bolt and nuts to hold the lip in position, some parts of the rear lip needs to be trimmed off as well
#109
Originally Posted by xizor
that is not the defination of "fitting"
Well, regardless, he did some modifying of the rear bumper so it does not fit unless you choose to do the same as K24A did.
#114
Hmm.. Im not quite sure of this. I would think it would with the right bumper.
#119
Originally Posted by ducksauce110
so if 04' fits 06' then i' guessing a m-style front end would fit an 06'?
Front end swaps fine
Side skirts swap fine
Rear end needs modifying to fit for both 04-05 to 06 or vice versa.
#120
Let's make it clear to those that keep asking the same questions over and over again.
2004-2006 Front Bumpers are Interchangeable.
2004-2005 Front Lip Kits will NOT FIT on 2006 Bumpers (Vice Versa)
2006 Headlights will fit on 2004-2005 Applications (Vice Versa) (Along with JDMs)
Sideskirts are interchangeable on all years.
Rear bumpers will need modifying for lip applications. I would assume the bumpers can be changed as well.
