Why is navigation asking for a security code?
Old Mar 11, 2006 | 10:57 PM
GuyIncognito's Avatar
When I got into my car this evening and started it up, the navi immediately popped up asking for a PIN. Not realizing it was asking for the security code, I tried using the PIN I lock the address book with before reaching into the glove box and finding the radio security code and entering that.
It took the code, but why is it asking? I have not disconnected the battery or done anything to the car that would cause it to forget. All my previous destinations were still listed in the menu, so I assume it didn't lose power.
Does the navi interpret certain behavior as abnormal such as frequency of car startup or unlock method? The last thing I did to it was roll the windows up by using the key in the drivers door, which I rarely do.
Old Mar 11, 2006 | 11:25 PM
jlukja's Avatar
Old Mar 11, 2006 | 11:30 PM
ATSX's Avatar
maybe its just a random thing the navi does.
Old Mar 12, 2006 | 12:51 AM
Reach's Avatar
It must have somehow experienced a loss of power, that's the only way/reason I know of that the navi will ask for its code. Second, did the radio also ask for its code? (separate code) If not, that would be truly strange.
Old Mar 12, 2006 | 01:14 AM
Still Water's Avatar
Maybe it was lonely and in need of a little attention.
Old Mar 12, 2006 | 08:35 AM
I'm not aware of a second code for the radio seperate from the Navi. I just typed in the code on that card they give you at the dealership and it started working again.
Old Mar 12, 2006 | 08:58 AM
CaptPJB's Avatar
Had same problem wirh 2006
My 2006 has done the same thing after about week two of ownership. Likewise no obvious power loss or battery disconnect. It took several tries to get it to accept the security code. In actual fact since it would not accept it I went to my dealer, they had the same problem but after about four attempts it accepted the code. No problems since in four months.
Old Apr 20, 2006 | 10:14 AM
slimbim's Avatar
Mine just did the same thing this morning. Got in the car to go to work, turn on the engine. NAV screen says "enter code". I enter it. works. Radio does not ask for the code. However, it did lose all the preset radio stations. This is strange. Why does it do this?
Seems like it lost power with Nav asking for code, and preset radio stations gone, but how come Radio does not ask for its unlock code then? And how could it lose power just parked there? I did not leave any interior lights on, nor headlights (has auto off anyways), and did not have any issues starting the car this morning....
Has people above exprienced this multiple times? or has it just happened once?
Old Apr 20, 2006 | 01:11 PM
slr's Avatar
slr
open the storage box from the front passenger seat, u'll see a sticker w/ a numbers.. the first 5 digit code is for the navi, and the second line is for the radio..
Old Apr 20, 2006 | 01:43 PM
bradykp's Avatar
Still Lovin my 06
storage box? you mean inside the glove box?
Old Apr 20, 2006 | 02:01 PM
slr's Avatar
slr
ow sory i mean yea the glove box.. dont know why i said that
Old Apr 20, 2006 | 02:16 PM
bradykp's Avatar
Still Lovin my 06
i've heard it called both i think.
Old Apr 20, 2006 | 02:49 PM
feliz's Avatar
Happened to me once, I had to go to the dealer. Never did figure out why and I never lost the presets.
The other thing mine does is quite often the upper part of the multi function display doesn't come on when I start the car, I have to use the steering wheel or psh knob to get it to work. When the car was new it would always come on when I started the car if it was on when I turned it off. It happens about one half the time now.
Old Apr 20, 2006 | 02:54 PM
parag_a2z's Avatar
Well, i had that problem once, when my radio was asking for the code. It happened when i plugged in a New Faulty Cell phone charger into the car....so i guess that blew the charger off, and the car battery got disconnected....so when i started the car the next time, it asked for the Radio code....
Old May 5, 2007 | 06:37 PM
achauhan's Avatar
9th Gear
I had the same issue
I faced the same issue. I had the code, so entered it to make it work...but was confused why it asked me in the first place.
I could have never thought the reason maybe this - but after reading the various posts here it maybe - the only thing that I did different which I had never done before was open the front passenger window from the drivers controls. Could the car really be intelligent enough to recognize such a minor abnormal behavior....cool!!
Old May 13, 2007 | 01:09 PM
Sojournin's Avatar
Out n about
This happened to me yesterday night. I started her up and it asked for the code. I hadn't done anything different except take the car to the dealer earlier that morning for an oil change (but I had run errands afterwards and there were no problems). So when it happened, I shut the car down and restarted the engine (it turned over as usual) - thinking maybe it was a battery drain, but it wasn't. I restarted the engine twice without problems. I wanted to see if there were other systems involved, so I armed the car and disarmed the car. I noticed that the driver's side door wasn't unlocking (the lock pushbutton on the door only came up half way). I tried this several times. The only way I could unlock the door was to use my key. After dinner the problem with the door unlocking went away, but my radio/navi still asked for the code. My preset stations still worked fine. I hadn't entered the radio code yet....I looked everywhere in the glove box and didn't find a sticker - just where is it supposed to be? (I have both codes on cards stored away).
Old Jun 14, 2007 | 02:11 PM
smn's Avatar
smn
i just had the same problem happen twice this month. has anybody found out any new info regarding this problem?
Old Jun 14, 2007 | 02:21 PM
rza49311's Avatar
I had this happen to me once in a year of ownership. It happened about 2 months ago. I drove my car to my gf's house around 6pm and parked it. Went to go home the next morning and it prompted me for the security code. Popped in the code and everything was fine.
Edit: my car is 2006
Old Jun 14, 2007 | 02:34 PM
nj2pa2nc's Avatar
it's a car-drive it
had to enter the code for my 06's nav once. No reason for it. works ok (knock-on-wood)
Old Jun 14, 2007 | 03:55 PM
siakol's Avatar
same here, just once.
Old Jul 29, 2007 | 10:30 PM
Rawism's Avatar
This happened to me today after my battery died and I need a jump start. But when I entered the code, only the navigation worked. I have to take it to the dealer in the morning in order for my radio to be turned on. I have an 07...
Old Jul 29, 2007 | 11:21 PM
SoCaliTrojan's Avatar
Let me help you!
There are two codes, one for navi and one for the radio. You have to enter the radio code. As I remember reading from another user, the radio code is entered via the buttons, not the navi
Old Jul 30, 2007 | 06:14 AM
nj2pa2nc's Avatar
it's a car-drive it
my tsx did that-no reason-started the car one day and it was asking for the security code. The radio worked-no code needed for it- the nav code and the radio code have different numbers.
Old Jul 30, 2007 | 09:37 PM
acura452's Avatar
5th Gear
It's probably a bug and you should tell your dealer about this. I have the same thing on my 2006 Pilot too. I've seen other Honda, Acura owners complain too.
Old Jul 31, 2007 | 11:09 AM
Let me help you!
I got my car to ask for my navi code when I started my car, remembered I needed to unlock the glove compartment, and I turned off the engine to use the key. The second time it happened, I turned off the engine, and then quickly turned it back on.
Perhaps maybe it's a loose fuse or something?
And why do they put the codes there on the glove compartment? If someone's going to steal your stuff, they might as well steal the sticker while they're at it. And if the stuff can't be stolen, then why put a code on the navi and radio?
Old Jul 31, 2007 | 11:51 AM
Meinbeast's Avatar
Im only prompted when the battery is disconnected.
Radio and Navi codes are separate. Radio code is punched in using the right turn knob, not volume knob.
Navi, is obviously done on the Nav.
My codes are located in my sunglass holder up top.
Old May 30, 2010 | 06:16 AM
RusTL's Avatar
Captain Morgan ))
How many digits the radio code usually is?
Old May 30, 2010 | 06:28 AM
nj2pa2nc's Avatar
it's a car-drive it
nav has 4 and the radio has 5
Old Jun 2, 2010 | 08:50 PM
REDmanCL-S's Avatar
Wow, this just happened to me over the weekend. Navi asked for a password. I went to the dealership and got it. Didnt lose anything ether. They told me it's due to a power serge. Apparently this is normal. (As everyone can see).
Old Jan 14, 2015 | 06:31 PM
Kaykay420's Avatar
2004 acura tl
Every time i start my car is ask for navi code why is this
Old Aug 9, 2015 | 07:20 PM
rjbush's Avatar
3rd Gear
I have the same issue only worse. My Nav will continually restart, and then sometimes it will get far enough to input the code. I had heard that sending to Alpine for a refurbishment will fix it, but this thread seems to indicate a drop in power. Has anyone figured it out?
Old Aug 10, 2015 | 10:28 AM
BROlando's Avatar
Mine was doing this when I first bought it. The positive battery cable was a little loose. I think maybe the other systems are equipped with a capacitor for intermittent (extremely small interval) power losses. The nav may not have one.
This is just a guess.
Either way, I tightened my cables and made sure they were clean, and it has been problem free for almost 2 years now.
Old Oct 9, 2015 | 01:44 PM
6speedtsx's Avatar
5th Gear
I have the same problem. When I try to enter the Navi code, it won't work.
dirleton
Aug 6, 2024 08:19 PM
Jamus22
Jun 11, 2023 10:08 AM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
thegipper
Sep 28, 2015 01:01 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
