when to change spark plugs
Old Sep 23, 2006 | 09:35 PM
palidanx's Avatar
honk not beep
i've been reading some posts about people changing their spark plugs at 30k, but the owners manual says around 110k. Any on this issue?
Old Sep 23, 2006 | 09:57 PM
PJS's Avatar
PJS
Plugs should be fine as per the recommendations.
Ours (European Accords) is 75K miles - mine has 79K and long overdue its 75K service, but it still drives fine.
Probably going to go for the Denso ones - not sure whether the longlife (another 75K) or the performance ones.
Old Sep 24, 2006 | 11:09 AM
foolioness's Avatar
Professional SLACKER
What is the best plug out there to replace the stock?
Old Sep 24, 2006 | 11:37 AM
aaronng's Avatar
Driver/Detailer
Stock plugs are either Denso or NGK Iridiums. They will last 75k miles.
Their part numbers are:
NGK - IZFR6K11
Denso - SKJ20DR-M11
They are basically the top of the range of street plugs. Any higher and you are looking at multiple prong plugs or the ones with extra thin electrodes (which last only about 45-50k). The extra thin ones are 0.6mm for NGK (Iridium IX) and 0.4mm for Denso (Iridium Power). If you are going for normal iridiums, both brands are similar. However, the Denso Iridium Power should give a better spark as it requires less voltage but they have a shorter lifespan.
Old Sep 24, 2006 | 03:38 PM
minkl81's Avatar
I just saw a ad from Bosch with its new plug called Bosch Platinum Ir Fusion. Looks same as Platinum 4 and it says they mixed iridium and platinum.
Old Sep 24, 2006 | 04:05 PM
PJS's Avatar
PJS
Cheers arronng - that's exactly what I was referring to.
The Iridum (standard fayre in the 2.4 engine) Power are the ones I'm going for as opposed to their long-life version.
Where'd you get the info on life expectancy of them? And I presume you're measurements are in miles rather than kilometres?
I don't recall seeing any mention of life of the Powers on the Denso site - just good info on mpg and bhp increases, although I am talking that with a pinch of salt.
Old Sep 24, 2006 | 08:20 PM
aaronng's Avatar
Driver/Detailer
It's in the service manual that I have. The numbers were originally in kilometers but I converted them since everyone uses miles on this forum. NGK even claims that their long life iridiums can reach up to 120,000 miles (192,000 kilometers)
I saw the Denso Iridium Power spark plugs here: http://www.densoiridium.com/spconstruction.php
The ground prong's design is interesting as well as it has a groove in it.
pstomps
Feb 20, 2017 03:29 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Sep 17, 2015 10:16 AM
Aleax
Sep 11, 2015 11:31 AM
NSolace
Sep 3, 2015 08:14 PM
