what sizes are the caliper bolts?
Old Aug 3, 2010 | 07:13 PM
super4's Avatar
does anyone know offhand what sizes the two bolts on the caliper are? i gotta change my pads and gotta go buy a few socketts i think they are 14mm or 16mm not sure? pretty sure i dont need any other tools right?, well just the rear caliper turning cube. thanx.
Old Aug 4, 2010 | 12:23 PM
kanonen's Avatar
TSX 2005 Manual
if u r doing front pads, you will need a clamp or a specifically designed clamp for pushing brake pistons that u can find at autostores for around $10.
Old Aug 5, 2010 | 12:41 AM
vlad04tsx's Avatar
6th Gear
c clamp works fine with the old pad on the piston for even pressure. also i have seen people use a large scredriver between the rotor and back pad. good if you are changing the rotors.
Old Aug 5, 2010 | 09:49 AM
curls's Avatar
Someone stole "My Garage"
You really only need a few sizes of sockets (and possibly some extensions) for our cars:
10mm (3/8" drive)
12mm (*)
14mm (*)
17mm (1/2" drive)
19mm (1/2" drive, for lug nuts)
(*) Buy those in both 1/2" and 3/8" drive and you'll have the sockets needed to handle most jobs on the car!
I believe for the brake pads you will need 12mm and 14mm, POSSIBLY the 17mm but I don't think so. You will also need a 14 (or maybe 17mm) open-ended wrench to hold the slider pin from spinning when unbuckling one side of the caliper to flip it open.
Old Aug 5, 2010 | 11:45 AM
super4's Avatar
done close it up.
its 14 and 12 for the calipers bolts and i just used an adjustable open wrench for the spinner screws.
neuronbob
23
Jul 16, 2019 10:48 AM
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
dirleton
Sep 25, 2015 12:25 AM
