What path does air take to enter a TSX engine
Hey all
I've bought a 2006 TSX that had been in a front end accident.
I have an OEM air box already but not sure where the air goes before it enters the air box. There were a bunch of crushed plastic tubes.
Here's a diagram of the air box -
What comes before the tube where the #7 is?
Could someone take a few pix for me? I'd really appreciate it.
I don't know if the 06 setup is exactly the same as 04, but if it is you draw air from behind your radiator. It then takes a 90 turn going through a wall separating a space from the rest of your car in front of the driver's side wheel well. After that it will go into a noise suppressor (forgot the technical name) which then leads up to #7. Do yourself a favor and get an icebox. Shortens your intake, gives you cooler air (relative), and you get a bigger volume air box
OP here are some pix from an Injen manual that shows how to install(uninstall) the oem kit.
http://www.carid.com/images/injen/ai...structions.pdf
It is for their cold intake but it works for what you want too.
rockyboy
Aug 4, 2024 10:35 AM
cycdaniel
Dec 17, 2019 10:58 AM
wusty23jd
Sep 24, 2015 11:41 AM
