What does it mean when your brakes turn yellow?
styling on you
1 Post
It's not my car. I went to go test drive a used TSX today and I looked at the brakes and they were all yellow, like the picture above. So I was curious what that was.
Also does that affect braking performance?
that happens when it was wet and wasn't driven around for a while. The moisture from rain/humidity builds and of course ur brake pad is basically steel up against steel. So you get rust. they come off right after you drive it around for a bit with some braking.
Let me help you!
My TSX looks like that sometimes...I notice it only when I get around to washing my car.
Yes it's rust. The circle thing you're talking about is the rotor. The silver thing on the left side of the rotor is the brake caliper, which squeezes the brake pads together on both sides of the rotor to slow it down.
Water can do a few things to rotors...it can warp them (never splash water on them if they're still hot...very hot metal cooled down quickly is a bad thing). It can help create a layer on the rotor between it and the brake pads, so braking is diminished (which is why you lightly press on the brakes in the rain before you expect to stop or after you run through a puddle). And it can cause rusting.
And as mentioned previously, it will come off when you use it...at least the areas where the brake pads actually touch the rotors (which is where it matters anyway). The rust on the outer rim (the side of the rotor) won't come off on it's own. You'll probably want to just brake lightly to get the stuff off. After than, you can brake as hard as you want
mmmmmm....
Originally Posted by SeCsTaC
As pictured...
BTW, is that called a disc brake or a disc rotor? I'm talking about the yellow circle.
Originally Posted by 1slowTSX
Yeah! I'ts light surface rust. It can form pretty rapidly(overnight). It'll come off after some driving and braking.
You mean after an hour. This always happens after I wash my car. I take it for a nice drive afterwards to get rid of it.
It's not a problem, no worrys.
rockyboy
08-04-2024 10:35 AM
mada51589
05-03-2022 08:54 PM
