What do you think about These LED?
1 set Super Bright and Wide Angle SMD LED interior package for 2007 Acura TSX for interior lights at JDM 5 Lights Deluxe Super Bright & Wide Angle Shine SMD LED Interior Package for Acura TSX 2004 to 2008 (Ultra Blue) <---For front side doors, map and rear dome lights.
1 pair Super Bright 12-SMD 360 Degrees Shining T10 LED bulbs for license plate lights at iJDMTOY Xenon White 12-SMD 1206 T10 Wedge Light Bulbs for Parking City Lights, Position Lights, Side Door Lights, Side Mirror Puddle Lights, License Plate Lights <--- for License Plate (anyone know if they are as bright as the Pure White WLED WHP found in superbrightlight?)
1 12-SMD Luxer1 LED at JDM Blue/White/Red Super Bright Luxer 1 12-SMD LED Interior Room Panel Lights <--- for Trunk light. (Will they fit?)
Link#1 you posted: For the dome/map lights, I would go with DE3175 from Oracle myself. They last. Any festoon bulb that is 30 or 31mm will work though.
Link #2: I don't know for sure, but a good guess is they will be about as bright as WLED-WHP give or take a little. There are more diodes, but the ones on the side might not make too too big of a difference since the tag bulbs point downward to the plate. The WLED-WHP has one big HP LED. Yours has 4 seemingly smaller ones on the front. One thing I do know for sure is that the WLED-WHP from superbrightleds prooved extremely reliable. I'd get those instead. A lot of people had frequent burn-outs with other bulbs as tag lights.
Link#3: The square LED pad will likely not fit in the trunk light lens compartment. It looks too big to me, but you can mount it outside of the lens compartment. The plug-in base for the trunk has to be 194/168 wedge. That will fit, but the body looks to big, and its not too safe to put things into an electrical compartment that weren't meant for it. There's a lot of metal and a diode in there that can cause a short if touched. Be very careful when handling the trunk light lens compartment when you try it.
With choosing LED bulbs for the car, the most important thing is to go with the most reliable bulbs in my opinion
How do the interior lights dim? Are they dimmed via pulse-width modulation, voltage, or current?
My real question is, do the LED replacement bulbs dim like normal, or do they just turn on and off?
Eggs999bacon
09-24-2015 10:08 AM
