What to do at 80,000 Miles
I'm almost at 75k miles on my TSX and I was thinking about a timing belt change and maybe all the other belts over there when I reach 80k. What do you guys think? I prefer to do maintenance soon rather than later.
Also, I read somewhere about replacing a PCV valve every few yrs or something, I don't think I've ever had this done. Should I and for what reason?
Originally Posted by briny319
I'm almost at 75k miles on my TSX and I was thinking about a timing belt change ...?
I have read that somewhere but I read on hondanews.com something about the 07 tsx's maintenance minder system:
To eliminate unnecessary service stops while ensuring that the vehicle is properly maintained, the TSX now has a Maintenance Minder System that automatically monitors the vehicle's operating condition... The system, which can be reset manually by the owner, monitors all normal service parts and systems, including oil and filter, tire rotation, air-cleaner, automatic transmission fluid, spark plugs, timing belt, coolant, brake pads and more.To prevent driver distraction, maintenance alerts are presented when the ignition is first turned on, not while driving.
http://www.hondanews.com/categories/740/releases/3783
But lets assume there is a chain, when should I change all of the other belts?
2004 TSX Maintenance Schedule
Belt/chain replacement doesn't show up in the normal maintenance schedule. I believe the timing chain is due for replacement at 110K mi. which is when the drive belt will most likely be replaced (and the water pump too). If you like to do your maintenance early I guess you can replace your drive belt at 80K mi.
Originally Posted by Tex929rr
The cam chain is designed to last the life of the engine. Where does this 110K miles come from?
But, I think this is one of those things that you take care of when you need to rather than preventively (at least certainly during the first 100K+ miles of ownership).
Originally Posted by rb1
I suppose the chain can stretch over time (and yes, they occasionally do break but it's very rare, much more so than belts, which break all the time comparatively speaking) to the point where the chain tensioner can't keep it within spec any more, at which point they would replace it.
If a cam chain breaks, you will definitely bend one or more valves and possibly even put a hole in the case. I guess it's theoretically possible to break a cam chain, but I've never heard of one.
Originally Posted by 04EuroAccordTsx
If you're worried about all these expenses and your car is paid off, just sell or trade in the TSX and get a new car.
My car isn't paid off yet but I was thinking about selling it soon but I think I want to wait for the new tsx next yr.
TF500
I wouldn't worry about replacing the timing chain as it's not a servicable item as such and isn't replaced as part of any scheduled maintenance.It wouldn't hurt to replace the drive belt though.
mada51589
05-03-2022 08:54 PM
Legend2TL
11-20-2015 07:31 PM
mugen_kid
11-13-2015 10:38 PM
