VSA prevented a big time accident
Is ironic as it may seem, the icon in my avatar could have possibly saved my life a few hours ago.
I was driving home on I-15 and heard a 'clicking' sound coming from my driver's rear tire. Initially, I pulled over to check if it had a nail, but didn't find anything. I figured it was nothing as I give it a few good kicks.
About 15 minutes later, I was doing about 85 mph when all of a sudden my car's backend went loose and I re-gained control of my steering. I noticed the car behind me make an emergency lane change as he avoided my tire's debris. At first, I thought it was simply a case of a rough, noisy road surface and my tires following the pattern. After I saw the 'VSA' and '!' indicator on, I knew I blew out the same tire that was making noise earlier.
Who knows what would've happened without VSA. Since the back end wanted to come around, I think the TSX would've ended up spinning and perhaps running into other cars or trucks. Now that I think of it, the VSA system managed to prevent a skid at 80+mph. The tire is toast. It looks similar to the reports here on AZ of TSX owners getting a blow-out due to running low tire pressure.
Aint technology grand?
Lesson learned: especially with chubby-profile, cheap tires like the Michelins, it's VERY important to monitor how much air is in them periodically. A few months ago, I ran the same tire below 15psi or so before patching up a nail hole. I had a bad feeling back then that the stress on the sidewall might come back and haunt me.
seizure force field!
technology is grand.
about what you actually said: I noticed something you might be wrong about...
under your name it says "VSA off 100% of the time"... dont you mean TCS (Traction Control System)? because that is what the " /!\ " in your avatar denotes (that TCS is off). When VSA engages I believe green letters appear. and when the TCS is on and it is engaged I believe TCS comes on or was it that little exclamation mark that flashes?
[QUOTE=v6cord2k5]technology is grand.
under your name it says "VSA off 100% of the time"... dont you mean TCS (Traction Control System)? because that is what the " /!\ " in your avatar denotes (that TCS is off). When VSA engages I believe green letters appear. and when the TCS is on and it is engaged I believe TCS comes on or was it that little exclamation mark that flashes?[
From what I understand the two systems more or less work "Hand and Hand " and also use the same icon....Please correct me if I'm wrong and its great to hear that your OK.
VSA caused me to buy a new exhaust 2 yrs ago. I'm traveling I-71N to Columbus during winter. It was sunny out and there was snow on the ground, but the highway was clear. However, I came up on a rural area and the car infront did a quick switch to the slow lane. I drove up onto compacted snow with ice on top. I let off the gas and the back end starts to come around. I stomp on the gas and VSA prevents the wheels from spinning, which in a FWD car with the rear coming around is the opposite of what you want. I immediately realize this and correct with a minor input to the steering. Car crosses from the fast lane beginning a 90 degree spin. I correct out of that and go 180 degrees into the median a$$ end first. Only the passenger side took the hit in the rear.
Long story summary... VSA is good, but only if there is traction to be had.
VSA is a type of traction control, and that's what Acura calls it, some other company might call it some other name like you metioned, TCS or what ever, but they are all traction control.
Driver/Detailer
Driver/Detailer
Have camera, will travel
Yep, all these technologies have their limitations, but that's not really the point. In Blk_6spd's case, it sounds like it saved his bacon. I hope I never need it like that, and at times it's a pain, but it's nice to know it's there if you need it
<--- I just updated the avatar.
Traction control differs from stability control. Traction control is pretty simple, and on a two-wheel drive car, its purpose is just to limit wheel-spin. On a fwd car, traction control only tries to distribute traction between both front wheels, preventing the wheel that's in the snow/mud from spinning while the opposite wheel just sits there.
As far as I can tell, there's no lamp on the TSX dash that indicates when traction control is engaged. And there's probably no reason for a driver to ever disable traction control.
Stability control is a different animal. Sensors on all four wheels detect loss or differences in lateral traction, and all four brakes are applied in varying degrees, but in concert, to prevent a spin-out. These systems are much more sophisticated than traditional traction control; some Ford stability systems actually use gyroscopes to detect when the vehicle is about to become out of control. (You may recall Ford's roll-over problems - they have reasons to build a first-rate stability system)
Traction control is easy to do. Saturn used to offer it as a $50 option a decade ago. Stability control is harder to do, but does more to enhance safety and will probably be mandatory in a few years.
Driver/Detailer
am I wrong?
Rep'n Taxbrain.com
Wow....I'm just glad to hear that you're okay man. I always drive with my VSA on, mostly just because I don't like seing that symbol on my guage cluster, but hey it's nice to know it can help out
When my dealer was giving me the tour of my TSX he recommended that I leave it off at all times unless I planned to do some drifting?????
Anyways I haven't taken the time to fully research the pros and cons of using the VSA so until then I'll leave it off.
Driver/Detailer
Originally Posted by Benz_05_TSX
Damn....and I know people who drive with the VSA off!
Originally Posted by aaronng
I leave it off permanently now ever since I was taking a nice curve at 45mph and the VSA detected a slight slippage in my outer front wheel. A split second later, the car was entering a spin in the opposite direction (VSA light came on) and I can to catch it with opposite lock. Same thing happened to another TSX on our convoy following behind me. Had VSA not intervened, I could have just reduced the amount of thottle to pull the car back in. VSA is good on the street, but not save for enthusiastic driving (btw, that road had a speed limit of 50mph)
Driver/Detailer
I have a module from KPTechnologies that keeps my VSA off unless I turn it back on. It basically remembers the last state the VSA was in (beit on or off) after the car was turned off and returns it back to that state with ignition on.
1) Get into the car, close door and lock. Seat belt on.
2) Hold down Dual + Auto, start the car
3) Press the rear demister 3 times
4) Press the VSA button
5) Wait 30 seconds
6) Drive off.
According to my friend, me starting up my car is like a pilot starting up his jet.
5) Wait 30 seconds
6) Drive off.
5) Wait 30 seconds
6) Drive off.
I forget, what is the Dual + Auto doing for you?
Driver/Detailer
What, no pre-drive checklist. You are forgetting to check the tires, make sure there is no water in the fuel tank and checking for birds in the nose cowl.
Dual + Auto put the driver's side climate control temperature setting display into diagnostic mode. Scrolling to option #4 gives the engine coolant temperature.
LOL, only thing I fear is a cat sleeping underneath my car.
TSX Navi AT 2007
Originally Posted by JTso
Someone stole "My Garage"
Traction control (throttle control is more like it) WILL flash the /!\ light when its activating. And, our cars have yaw sensors that detect slight drift and correct using the VSA sub-system, by applying one, two, three, or all 4 corners' brakes.
aarong: Does that DUAL + AUTO thing work for non-NAVI cars? If so, I gotta try that today!
Glad you are alright!
ABS has saved my ass more than once.
Here's a VSA related question. The entrance to my workplace is on a large road (speed limit 45 MPH) and you take a right turn and immediately go over train tracks. These tracks have a big metal stripe between the tracks. When it is wet and I take the corner any faster than about 10 MPH, I always get the back end flying out.
VSA has never come on when this happens. It just seems odd because at times I have forgotten to slow down and I end up having the back end of the car swing a good foot or two out before I pass over the tracks and regain traction. I would think VSA would at least come on (though I doubt it could do anything about it). Could it be because the front tires have traction?
BigTimeBooch: That definitely sounds like a situation where VSA should kick in... although it depends - maybe you aren't noticing it trying to intervene because it happens so fast (ie: you might not see the momentary flash of the VSA light, because driving voer that metal strip only takes 1/4 of a second). Even if it did try to intervene, I don't think it'd be able to do much, as wet metal = slippery as heck.
Driver/Detailer
Driver/Detailer
Originally Posted by xenonhid
VSA is great! I did not know that VSA could stablize the car in that type of situation.
Yes, it should work with non-navi too.
Driver/Detailer
Yes, it worked, thanks! Although this struck me as strange -- When I was on the Coolant Temperature option (option 4), when I first started my car, it was at 32* C. However, the car had been sitting outside for about 14 hours, and the temperature overnight dipped to a cold-as-heck -22*C. How the coolant temp stayed so warm is beyond me!!! For what its worth, the coolant temp gets to about 82*C and no higher -- I'm assuming that's when the thermostat opens fully and the radiator fan starts becoming operational.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
