Upper front control arm bad
Old Jun 14, 2016 | 06:28 PM
Ck98vteC's Avatar
Should I replace just the one that is bad, or do the right side too? My dealer confirmed the left one was bad which causes clunking.
Old Jun 15, 2016 | 09:49 AM
BROlando's Avatar
I'd be inclined to replace both. They've both been through the same treatment. Maybe one hit a few bumps harder than the other. But they're only seperated by like...4 feet.
You'll need an alignment after replacing a UCA.
Old Jun 15, 2016 | 12:04 PM
mrgold35's Avatar
mrgold35
I had a bad upper passenger control arm. It wasn't clunking; but, I couldn't get the it into alignment specs. Replaced just that one with OEM replacement and still couldn't get it into alignment specs. Just went with Heel toe ultimate front/rear adjustable camber set and back in alignment green. My rear camber was slowly getting more out of specs anyways with +100K on the A-spec suspension. I was able to fix both problems with the camber kit.
gavriil
Aug 20, 2025 04:43 PM
00TL-P3.2
Feb 11, 2019 11:23 AM
username123
Aug 2, 2016 02:40 PM
marxw13
Mar 3, 2016 09:16 PM
DallasB
Jan 26, 2016 08:44 PM
