TSX vs. GLI by owner of both
Just picked up an automatic 2006 TSX for the wife yesterday, replacing my 2004 manual Mazda RX-8. About 6 months ago I leased a 2006 GLI with DSG, meaning I can do an auto vs. auto comparo. I've been really happy with the GLI, so it's going to be tough to be impressed by the TSX. I'll report back when I have more seat time in the TSX.
If my wife can drive it, it's an automatic
Seriously, the DSG, while technically a clutchless manual, has fully automatic modes, so someone shopping for an "automatic" wouldn't have to adjust at all to driving the DSG.
BTW, my son has a manual 2006 GLI. I was going to show him how much faster the DSG is , but he just had it chipped. I'll need to do that too.
I can tell you that the TSX has a much better looking interior, better ride quality (due in part to its tires), and at least as many programmable gizmos as the GLI. Much quicker performance in the GLI drivetrain, but not sure about which handles better yet.
Not sure what the OEM tires on the GLI are, but the TSX OEMs suck big time for performance (and safety). Put a few miles on 'em and they suck for road noise, too. My advice - dump them asap. I factored in the cost of new tires into my budget when I bought the car and installed Yoko Avid V4s at < 2k miles (want/need all-season).
I mention this because you're "comparing" handling and tires can make quite a difference.
Originally Posted by psteng19
It's not exactly auto vs. auto.
It's DSG vs auto, DSG having a huge advantage.
Torque converters are
The DSG is technically an automatic with a clutch (actually two), not a manual without one.
From M-W:
au·to·mat·ic, adj:
1 c: done or produced as if by machine
man·u·al, adj:
1b: worked or done by hand and not by machine
DSGs are automatic transmissions. They happen to be some of the technically best automatics out there, but that's hardly relevant: there are cars with seven-speed slushboxes and single-clutch automatic transmissions that are faster than any car with a DSG. The defining characteristic of a manual transmission is not performance -- it's that you have to work it yourself.
The OEM tires on the GLI are Bridgestone RE050 - summer performance, but not very good in their class (not to be confused with RE050A). I had the TSX Michelin tires on my Mazda6 previously and I can verify they aren't very good.
^^Well summer tires are summer tires. Compared to the TSX's sucky grand touring jobs, you can probably attribute whatever handling edge the GLI does have to the tires. That is, if it has any advantage at all.
The GLI's springs are far stiffer than the TSX's, but when I was test-driving both I didn't feel that there was much of a handling benefit (certainly not enough to compensate for the reduced ride comfort). With a Comptech RSB on the TSX I think they are pretty closely matched. But then I only drove a GLI for about half an hour, a few hours before I drove a TSX for the first time, so maybe someone who actually owns both can make a better comparison.
Originally Posted by PixelHarmony
I'd love to try out that DSG...
It is simply amazing. I had a really fun time with it. Acceleration is great when compared to the TSX. But.. i dont think i would give my TSX up for it. 1 reason is that the TSX simply looks better inside and out. The ride quality is also much better. Plus, i have to have manual..none of this Auto / DSG crap.
Originally Posted by jpt
No!
From M-W:
au·to·mat·ic, adj:
man·u·al, adj:
From M-W:
au·to·mat·ic, adj:
man·u·al, adj:
You're definitions are of the words themselves and are also completely out of context.
We are speaking in car terms here and a manual is synonymous with having a clutch (and until recently, a clutch pedal), while an automatic uses a torque converter.
Again, no one wrote the official book on this but it's widely accepted by many, if not most.
You'll also have to have to define "work" or "work it yourself."
Who's to say that "working" the paddle shifters, or pulling the lever from P to D is not 'manual' work?
So if I'm "shifting" from 1 -> 2 -> D3 -> D4 in an auto transmission, am I all of a sudden driving a "manual"?
If any idiot can drive it, it's an auto. Any idiot can drive DSG just like any idiot can put a lever in D and floor it and beat his chest afterwards. Any idiot can "shift" DSG just like any idiot can "shift" any other manumatic.
Who's to say that "working" the paddle shifters, or pulling the lever from P to D is not 'manual' work? So if I'm "shifting" from 1 -> 2 -> D3 -> D4 in an auto transmission, am I all of a sudden driving a "manual"?
If it ain't got three pedals, it ain't a manual transmission!
If it can put itself in gear for you, it ain't a manual transmission!
If you can't stall it, blow your engine up by over-revving, or shift so poorly your passengers spill their Big Gulps, it ain't a manual transmission!
Ok, as per my original posting, I've had a week to compare the 06 TSX to my 06 GLI. I'll exclude the power difference, since I knew going into the purchase that the TSX auto can't compare to the GLI DSG.
The TSX is more comfortable, more luxurious, quieter and much better looking inside.
The handling with the TSX is about 3 levels below that of the GLI. Steering response is worse, leans more in turns, and has little of the road feel that the GLI has. I WILL ASSUME that the crappy Michelins on the TSX are mostly responsible. Can anyone verify that switching rubber makes a big difference, and if so, what tire is recommended that won't totally kill the very pleasant ride qualities?!?
The above criticism of the TSX is only in comparison to the GLI, which excells in the handling department. I'm not saying the TSX handles badly, but in an A B test between the two, it does. Please don't take offense at what I've said. After all, I decided to buy (lease) the TSX so I must like it!
The GLI has 17 inch wheels (standard) with 225/45/17 Bridgestone RE050 summer tires (not very good in their class - I had BF Goodrich KDW2's on my RX-8 which were awesome, but extremely noisy).
As stated, the road feel is lacking in the TSX compared to the GLI, tracking is less precise, and I just get the feel of driving a good handling luxury car, rather than a SPORTS SEDAN. I had the same TSX Michelins on my Mazda6, and I immediately switched to Bridgestone 750's which make a big improvement in the feel in that car.
I live in Florida, so I can go with summer tires all year round. Recommend a tire for me. I don't want to change the wheels at this time, since I plan on doing mods to the GLI first.
As for the tires, the Avon M500 seems to be a highly recommended tire here. I have the same noise problem with BFGoodrich tires that I am running now so if they wear out before I decide to get another car, I may switch to the Avons, myself.
REO50A is optional on GLI w/ 18" wheels. The GLI pretty much beat up the TSX in all performance catagories. It does fall short in the luxury end though Car and Driver pitted them against eachother. The TSX was said to dtill be the classiest of the bunch but definitely needed more power to keep up with today's offerings. Even the Accord beat it out on most performance areas. Which is no suprise since the TSX is really just an Accord. If Acura decides to address the power issue then the TSX should eventually fair a little better.
SidhuSaaB
05-30-2020 12:40 AM
Puma Jim
20
10-20-2016 11:59 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
