TSX Trunk Tray?
Hey guys, I'm contemplating purchasing the tray, but am curious to if items tend to slide around more on the plastic tray opposed to the carpeted trunk. I know there are benefits to the tray (protecting the carpet, spills, durability, etc.), but I can't justify it if items are constantly doing the electric slide.
Originally Posted by moda_way
The tray has saved my trunk MANY times as well.
someone left a bottle of corona in my trunk the other night and the cap was leaking. i orignally didn't want the mat as they threw it in as part of the vehicle. now i cant imagine not having it. i've driven a few loaners and it's awkward for me now to see the trunk just lined in carpet.
Ever since my wife insisted on putting a new bottle of bleach in the trunk insisting that it'll be ok, only to get home, and find that it fell over, cracked the cap and dumped out everywhere. =)
Always the trunk tray for me!
Originally Posted by smock9
where are you getting it? dealer?
www.hondaacuraworld.com (free shipping i think).
Originally Posted by huckleberry
tray + $3 bungie cords = works fine for me, no need for that PITA net.
After installing ElDude's fiberglass sub enclosure, I could no longer use the OEM net. I just use bungie cords now.
I guess I should get a 350 net and try that.
I purchased the tray, well worth it. Shop around online you can get it cheaper than buying it with the dealership, at least that was in my case.
Later
Damon
2006 TSX
TSX Avg MPG
Later
Damon
2006 TSX
TSX Avg MPG
One nice beni for me having the OEM net installed when making the grocery run I simply place all the bags across the back of the trunk and drive off. Never had a problem tipping over a bag and I still have most of the truck open. It's like having two separate trunks.
Later
Damon
2006 TSX
TSX Avg MPG
Later
Damon
2006 TSX
TSX Avg MPG
But cool... a fellow lawrenceviller... hehe
By the way... are you actually typing your links for your signature after every post? You can add a signature you know. Goto user CP and set one up. Then after every post just check the box that says "use signature". No need to type it in everytime.
For those with the 350z cargo net... does it lay "across" the trunk, or does it create another "compartment" like the OEM version does? I've heard the OEM net is a PITA to install, but I don't want to pick up a 350z one if I can't even use it to store groceries in, for example...
Originally Posted by Alin10123
Not to hijack the thread...
Not to really hijack your thread but how do you guys like it in the Atlanta area? I might move out there in the next year or 2 but I know nothing about it. Other than the humidity is really high? Looks like a really nice area with alot of pretty scenery. Trees, hills, greenery etc... Where I live now, it's really bland. Nothing but alot of farmland and its flat as a pan cake.
netters....
I know how the OEM one works since I have that in my Accord coupe-- it makes a moveable vertical wall that snugs up against the rear of the trunk using 8 available hooks. and it also contains a pocket to hold smaller stuff. That 350Z net seems to just hold things down to the floor of the trunk --based on JTso's pic in another thread. This would be a completely different application than OEM--which I always use in the accord. though the 350z version looks like it covers much more square footage than the OEM.
Can the 350z net be used to make a vertical wall?
thanks, ed
thanks, ed
thanks, ed
Originally Posted by xizor
No, it only works flat. The TSX one requires drilling which turns most people off
Just got the trunk tray last night. Thumbs up. Perfect fit - no more muddy hiking boots or running shoes dirtying the carpet in the truck. Not that I'm, ahh, obsessive about that or anything.
Picked up the cargo net too...not much in the way of instructions for drilling. Woof. That will go in this coming weekend.
mlody
Dec 4, 2019 02:11 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
Sep 25, 2015 06:14 PM
justin.w13.walker
Sep 22, 2015 02:21 PM
Are you ripping it around every corner and have stuff bouncing around your trunk? Because if not, then you won't hear anything knocking around, even with the cargo net.
