Range reset
Old Apr 18, 2006 | 12:27 PM
CoquiTSX's Avatar
Range reset
Do you have to fill up the tank in order to “reset “ the range readings from the display (MID?)? I was running low on gas, I added a couple of gallons so I could fill up at another gas station. The range did not change, and eventually I drove another 30 miles after the range was 0. It was still calculating mpg, even though the tank was “empty” . I don't want to reset the display till I reach around 1K miles. The car is an 05 with Navi.
Old Apr 18, 2006 | 12:38 PM
frescagod's Avatar
2010 6MT non-tech
i believe you have to fill up for the range to reset. i haven't reset since like december, but the range always goes back to ~400-ish when i fill up (i always fill up, not add 2 gallons at a time)
Old Apr 19, 2006 | 11:49 AM
CoquiTSX's Avatar
Most of the time I fill up. I just put enough to get to my favorite refill/rest stop on the way back to MD from the inlaws. When I fill up it goes up to ~400-ish too. Thanks.
Old Apr 20, 2006 | 01:47 AM
Johnson8537's Avatar
so how quick does this feature work... i have it turned on in driver preferences but before i moved on my first fill up i manually reset it because it didn't reset trip A.
Old Apr 20, 2006 | 05:16 AM
CoquiTSX's Avatar
AFAIK Trip A & B have to be reset manually. The driver preferences resets the range,mpg, time and avg speed on the MID.
brboy
Oct 5, 2015 11:34 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
Skirmich
Oct 1, 2015 12:59 PM
Froid
Sep 27, 2015 06:16 PM
ceb
ILX
Sep 27, 2015 10:56 AM
