TSX HID projectors
TSX HID projectors
just couple of questions regarding the headlights. Does anyone know how much Ks does the stock HID bulb outputs? Does the headlights have any auto leveling devices for the HID projectors? Thanks!
Moderator Alumnus
The stock light bulbs are Phillips 4100K. It is the closest color temperature to the sun's light, thus the most efficient.
And I don't think the TSX has auto-levelling. (unfortunately)
Well, close but not exactly. The 4100K is a compromise. Philips has HID bulbs at 5800K as well, which is much closer to the color cast of sunlight. (Sunlight is considered to be 5500K) However, such HID lamps tend to not put out as much light as the 4100K lamps. As far as I know such bulbs are not yet street legal int the US.
Anyway, color temperature is not the only important spec for light bulbs. The CRI (color rendition index) is also important, and it indicates how well a bulb represents all visible colors. The higher the CRI, the higher the color fidelity.
! deadmau5 !
Umm... That guy I got my Bosch fog + driving lights from is a propellor-head on this stuff. See: http://danielsternlighting.com/nhtsa/NHTSA.html
-- and be prepared for the 66-page highly technical PDF that follows.
Bottom line is that YES we DO have auto-levellers, and that it's required by the US Dept. of Transportation's associated regulatory bureau, the NHTSA (National Highway Traffic Safety Administration).
BTW -- if you scan through this report, you'll see why you don't want to put in "blue bulbs" and a lot of other useful light-related data... and why "manual levellers" are insufficient for HIDs. But Acura's marketing releases don't explicitly tout the TSX HID system which is, I think, a shortcoming of the marketing team (not the car.)
The light from car HIDs doesn't even remotely approach any characteristic of the sun's light. The sun's light is a continuous spectrum from red to violet; HIDs (automotive and in general) have a discontinuous spectrum made up of peaks (in violet, blue and green especially) and valleys (in yellow especially).
The CRI (Color Rendering index) is on a scale of 0 to 100, and indicates how accurately a light source renders colors relative to a controlled condition that involves noonday sun on a cloudless day at a particular global location. CRI is directly related to the characteristics of a light source's spectrum, for obvious reasons -- the sun is a continuous-spectrum source, so continuous-spectrum sources have higher CRI than discontinuous-spectrum sources. The CRI of a tungsten-halogen bulb is extremely high, around 98 to 99. The CRI of a standard automotive HID is much lower; Philips states "minimum 73 with new burner". The CRI of these "high color temperature" HIDs is much lower again, in the mid 60s.
It is an absolute myth that higher color temperature is "better". It's not! It causes more glare, reduces color rendering and sharply reduces the amount of available light. Example: Philips D2S automotive HID bulb, 4250K, 73CRI, 3200 lumens. Philips D2s "Ultinon" automotive HID bulb, 6000K, 65CRI, 2550 lumens. And that's without even getting into these silly 8000K, 10000K, 725522K etc. cheesy no-name HIDs.
The TSX has good HID headlights. But it's not because they produce light that's like sunlight (they don't) or because they have a higher color temperature. It's because they're well designed and use a good, strong light source.
! deadmau5 !
Originally Posted by Chnaane
Um, dude, read the PDF. He spends a lot of time talking about how auto-levellers are allowed but *aren't* required in America, but are required elsewhere on the planet.
So, Chnaane, since you seem to already know a great deal about this stuff -- do the TSX's low beams classify as "auto self-leveling", or not? I can't believe they'd put a cheaper lighting system in a Japanese-manufactured car just for the US market.
-- And if we do have "self-levellers", why don't they just tell us?
(I'd ask a bonus question about whether the damping on the HID housing's movement is fluid or magnetic -- and I suspect you'd know -- but right now, I'd be happy if we could establish some basic language about whether the HIDs "level" or not.)
9th Gear
-DS
Just curious -
If the headlamps are aimed properly by the manufacturer, unless you physically change the aim or get in a front-end accident, they why would the lights move and change aim in the first place? I've seen the Lexus system work when the lights are first turned on. Are these levelers supposed to keep the lights properly aimed always, or just make sure they're level when they are first turned on? I'm no expert on this, but when travelling at highway speeds and hit a bump, I can't think that the levelers can work fast enough to keep the light from moving aim and not give other drivers on the road the flashing effect common with HIDs.
all oem hids are 4100k or 4300k or whatever it is. NONE are 5000k 6000k or any of those gay K's. the higher the number, the less light output. people who don't know anything about hids buy those kits for the stupid color.
! deadmau5 !
Originally Posted by nct1596
Just curious -
! deadmau5 !
Originally Posted by Scheinwerferantwortmann
Check for yourself! Point the car at a vertical wall after dark, turn on the low beams, then start the engine and watch the beams on the wall. If they dip down and then raise, that's an autoleveller's self-test procedure and you have autolevelling headlamps. If not, probably not.
Autolevelling and headlamp cleaning systems, required with Xenons outside North America, is not required in North America and so is frequently absent from Japanese cars with Xenon headlamps. Same goes for all kinds of other safety devices ...
It's neither; the levelling is carried out by a worm-geared stepper motor.
I've got auto-levelers in my RX330. They go thru a test proceedure that they go up and down twice at each start up.
When you hit the brakes, and the front end dives, the lights adjust up so that you arn't left with a really short light distance.
When you nail the throttle and the rear end squats, then they adjust down to keep from "dazzling" on comming traffic.
It is fun to play with it. Tag the gas and watch them ajust and vise versa.
AFTER ALL THAT, I AM NOT SURE IT IS WORTH MUCH.
For example, my TSX has already had the clutch master cylinder replaced, the windshield removed and resealed (A-pillar rattle) and now in for the entire radio (all the center stack back lighting went out). I also think I am starting to experience some disk brake warpage (not 100% sure, time will tell). If Acura has to build my car more crappy than they already have to give me Auto-levelers, I would say forget the auto-levelers.
Sorry about the rant. I am just getting tired of taking my "near luxury" $26K Honda back for service more than my Mustang or previous Jeep.
! deadmau5 !
Originally Posted by sveet
I've got auto-levelers in my RX330...
...my TSX has already had the clutch master cylinder replaced, the windshield removed and resealed (A-pillar rattle) and now in for the entire radio (all the center stack back lighting went out). I also think I am starting to experience some disk brake warpage...
Back to this thread -- we pay particular attention to lighting issues (see the Bosch threads) and if we'd known the HID system was "well-designed but deficient," in that there was no mechanism to aim the HIDs properly, that would have eliminated this car from purchase consideration.
9th Gear
Just curious -
-DS
9th Gear
Originally Posted by dagigu
i thought the stock HID bulbs are phlips 4300 K!?
D2S and D1S (from Philips, Osram and GE-Tungsram) run in the very close vicinity of 4250K.
D2R and D1R (from Philips, Osram and GE-Tungsram) run in the very close vicinity of 4150K.
-DS
9th Gear
OK, I have a vague mental picture of this... but it's a one-time adjustment at startup, like a digital autofocus camera in "single focus" mode.
No, that "one time adjustment" is just the initial self-test.
I can't picture the stepper constantly making microadjustments
And what happens if the car's parked on a steep hill -- like in San Francisco? You start driving, the HID leveller determines what it thinks should be "level", and then you move from 20-degrees positive to 20-degrees negative.
-DS
9th Gear
(Come to think of it, don't think I've ever encountered a hetero one, either.)
-DS
True and correct.
Don't think I've ever encountered a "gay" headlamp.
-DS
-DS
Moderator Alumnus
True and correct.
-DS
-DS
! deadmau5 !
This is what I'm not sure about --
1. How much do HID and halogen bulbs change as they get older? Is a 4150K bulb going to be down to 3600K in two years -- and how about the total light output?
2. Can anyone visually see a difference between say 4250K and 4150K? If a bulb gets replaced, should the opposing socket also get a new bulb?
3. I'm hearing more about LEDs being used in serious lighting situations -- they're already here for some car tail lights. You mentioned rear turn signals in a prior post -- so why can't we just put yellow LEDs in our rear lamp housings to shine through the red lens?
4. And will LEDs ever be strong enough for front lights?
9th Gear
Smartass
you know exactly what the meaning was.
-DS
9th Gear
Yes, but this is one of the ways CCT breaks down as a useful measure. Two light sources can appear markedly different from one another and still produce light that is said to have similar CCT. The visual difference between a new and an old automotive HID burner is usually fairly apparent if you're paying close attention, but its obviousness is highly dependent on the optical system. Some projectors, for instance, have a cutoff shield deliberately shaped and placed to created a strong blue fringe right at the cutoff. This tends to mask the operating-color differences.
--DS
9th Gear
Originally Posted by jsharper
Does anyone know how much the OEM headlights cost to replace in the TSX if they fail?
If a ballast fails, you can either replace with OE from the dealer ($$) or use a name-brand aftermarket unit that may not be the same size/shape, but will function as well or better.
If someone smashes or steals your complete headlamps, your options are the dealer or a "parts recycling" place (used to be called junkyards).
-DS
Moderator Alumnus
I'd rather be a smartass than a dumbass.
Yes, of course I did. Apparently you think "gay" is a synonym for stupid, pointless, dumb, illegal, bad, etc. I wonder, do you also think "black", "jewish", "Chinese" and other minority referents are synonymous with stupid, pointless, dumb, etc? Bigotry is way, way, way more uncool than faggotry, dude.
-DS
-DS
Meanwhile, here's a song for you to watch
! deadmau5 !
[OEM headlight bulb replacement cost]
So the answer is ... it should be covered under the Acura 4-year / 50,000 mile warranty. And outside of that, in four years' time the technology might be even better -- but "D2S" is a standard size, so we'll have a number of choices.
Depends what kind of failure you experience and where you buy your replacement parts. The TSX uses a completely standard D2S bulb. Usually several hundred dollars from the dealer, but under a hundred from aftermarket sources of OEM-quality name-brand units (acceptable name brands are Narva, Philips, Osram, GE-Tungsram).
! deadmau5 !
HIDs tend to grow less intense and experience a color shift with age. The direction of the shift isn't uniformly predictable, since it depends on operating factors and original burner chemistry
[Changing two bulbs at a time -- ]
Situationally dependent. If a bulb fails early, there may not be enough color/intensity difference to make it worth spending doubly. If one bulb is relatively old and the other is new, there will often be a visually-apparent difference.
After the Acura warranty is finished, buy name-brand D2S 3rd-party bulbs and ballasts, and use the savings over OEM to get both bulbs at once.
Several reasons: (1) They'd appear red, because of the red lens. (2) You can't just cram LEDs behind a lens and have it work as a proper tail/brake/turn/whatever light.
Yes. The new Audi A8 has LED DRLs, and LED headlamps will arrive in a few years.
Canadian TSXes have DRLs, but for the US it wasn't implemented (though all the wiring and fusing is in place). A few people have asked for DRLs, though ... so the optimal answer is to build an LED copycat of the A-8, and it can be installed right where that all-but-useless Acura OEM fog kit goes. (This also works out terrific for me, because I've got my center grill packed with Bosch fog & driving lights, and the corner locations are still unused.)
9th Gear
Good luck with revolutionnising the internet man.
My comment wasn't aimed at "revolutionising the internet". I was just pointing out your grade-three behaviour, is all.
Moderator Alumnus
Edit: Don't get me wrong, though, obviously you have extensive knowledge with HID technology, and I appreciate that for sure. But there's no need to rise above others moralling them.
! deadmau5 !
And I was pointing out ...
We need extra brainpower applied on this LED-based daytime running lights thing. Even if you already have Acura OEM fogs.
Schw[-whatever] cited the Audi A-8 so there's a terrific opportunity to make up a unique and cool design long before the corporate (or the aftermarket) catches up.
And there's also the larger opportunity to permanently fuglify your TSX, which is what some people think I did with the Bosch lights. :-)
So here's the question: if you were given the task of making DRLs using LED components -- and only minimally changing the rest of the car -- what would you come up with?
Moderator Alumnus
Oops! :spankme:
Seriously, I don't know if it would be really possible to truely make a well done, professionnal-looking LED type DRL, especially on a car that is already equipped with them. Maybe a LED crown around the highbeams would look ok, but then again, I sort of doubt it.
! deadmau5 !
That leaves external lighting as the main form of personal expression, sad to say. The usual Jersey way is to leave all your aux lights on all the time, regardless of weather or time of day.
DRLs are a mandatory option I never cared for on my Yukon -- who can't see this without its lights on? -- but if you look as a design rather than a safety feature, there's a chance to do some good on the TSX.
You're talking about putting a ring inside the Lexan around the halogens. Neat! My own thoughts were about drilling holes in the plastic bumper for LEDs to stick through, like down into the corner foglight area, and also seeing if we could track down the Euro JDM headlight washers that Schw* mentioned.
Unfortunately my experience has been that the front and possibly rear plastic bumper fascia is a disposable/replaceable item, and you probably need to plan on doing so once every 3 years or so.
Some of the HID look alike bulbs that are halogens have a coating to make them seem whiter, which they do have a higher color temperature (K), but actually less lumens, or light intensity output.
Got Milk???
I've seen a few BMW M3's with really blue-ish white low beams. The blue-ish color is not coming from light refraction through the projector, but genuine blue-ish white. Visually, they seem to be a lot brighter than our TSX oem low beam xenon. I have read the thread that our TSX low beam is 4100k, so what would this low beam on the M3 be????
-KC
-KC
