TPMS question, pls help
Old Aug 24, 2009 | 11:47 PM
extracrunchie's Avatar
Hi i was reading the handbook and was reading about the TPMS and about the sensor......and for winter rims i might be just getting black steelies......so my question is, would that affect the TPMS? or should i take it to the dealer to get the tires and rims?
Old Aug 25, 2009 | 07:50 AM
SHYUperman's Avatar
J M U ... DUUUKEESSSS
The TPMS sensors are mounted inside of your wheels. If the winter rims have TPMS sensors installed that are compatible with the TSX, then you will be fine. If not, you'll have to buy a set and install them on your winter setup. This can be done at any tire shop for around 20$ per tire.
You can get a set of 4 off ebay for 80$ shipped
http://cgi.ebay.com/ebaymotors/4-ACU...Q5fAccessories
Old Aug 28, 2009 | 06:52 PM
Simba91102's Avatar
Old Guy
Or you can take a vacation from the nanny state for the winter and just go without. You'll have to put up with the little yellow exclamation point (alerts you that something is amiss), but other than that, you'll be all set.
Old Aug 29, 2009 | 12:32 PM
as long as there is no beeping, ill be fine........
Old Aug 29, 2009 | 03:25 PM
meezie's Avatar
I haven't incurred any problems, yet, with my TPMS on my TSX. But on my previous car, on a set of wheels I had, I didn't use my sensors and all I would get it is a indicator light.
Old Sep 6, 2009 | 11:07 PM
Dktran31's Avatar
just make sure the tires you get are compatible with TPMS, if your ordering online , most major websites will tell you if they are or not
Old Sep 8, 2009 | 06:38 PM
Simba91102's Avatar
Old Guy
For clarification here, I assume he meant wheels. Tires have nothing to do with it.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
johnalfa
Nov 5, 2015 06:44 PM
RobbDizzle
Oct 15, 2015 11:16 AM
navtool.com
Sep 25, 2015 05:15 PM
