From TOV: TL in 6th vs TSX in 6th
http://www.vtec.net/forums/one-messa...ge%5fid=205088
Just a quote, as its best you go there.
Before the TL guys get into an uproar. Note it was only in 6th gear. The TL would walk the TSX under any other situation.
My suspicions were correct - time after time, the TSX simply walked away.
Hmm, I guess the gearing of the TSX does have its advantages despite it not being perhaps as fuel efficient as it could be (if it were geared to churn out fewer rpms in 6th).
If we look at the gear ratios ...
TSX -> 0.66 6th * 4.7 final drive = 3.1
TL -> 0.77 6th * 3.28 final drive = 2.42
At 3100 rpms, the TSX is at or near max torque of 150 ft lbs to the wheels, * 3.1 = 465 ft lbs of torque.
In order for the TL to match that output it needs to produce 192 ft lbs at wheels. Also keep in mind the weight difference so realistically to start pulling as hard as the TSX the TL will need over 200 ft lbs of torque. I havent seen a TL dyno but obviously it doesnt have that kinda power.
So really what does it all mean? Nothing cuz the guy in the TL is just gonna gear down and smoke our asses
Is that a typo? :P
that "*" means multiply. apparantly, that's how you figure out torque to the wheels (mutlipy gear ratio by engine torque)
i guess, not sure about the validty of that, but that's how he got the number
mlody
12-04-2019 02:11 PM
GWEEDOspeedo
01-15-2016 10:39 PM
