TL vs TSX engine
Old Feb 26, 2004 | 01:08 PM
  #41
rb1's Avatar
rb1
Originally posted by ClutchPerformer
And a belt doesn't imply an "infinite" number of teeth. If it did, you'd get an infinite gear reduction and you'd break something. To my knowledge, this only happens with toroidal CVTs (which the Audi is not), but I still don't quite understand how.
Not what I meant. I wasn't suggesting that the number of teeth had anything to do with the ratio, only that a smooth belt (like in the CVT) is the same thing (theoretically) as a toothed belt with a very large number of teeth. You were suggesting that lots of teeth = lots of inefficiency and I was just using this as an analogy.
I don't see what practical effect the number of teeth in gears has on efficiency. Besides, in an MT car the actual gears are helical, while I don't think an AT has helical gears (but I could be wrong) as I don't see how they would dynamically mesh.
Old Feb 26, 2004 | 02:03 PM
  #42
ClutchPerformer's Avatar
Originally posted by rb1
Not what I meant.....You were suggesting that lots of teeth = lots of inefficiency and I was just using this as an analogy.
Sorry, didn't catch your analogy. I was suggesting that MORE teeth = MORE inefficiency. It's not necessarily a LOT more inefficiency, but there is a difference.
....I don't see what practical effect the number of teeth in gears has on efficiency. Besides, in an MT car the actual gears are helical, while I don't think an AT has helical gears (but I could be wrong) as I don't see how they would dynamically mesh.
There's friction (fluid and sliding) when gear teeth mesh. The more teeth mesh per unit time, the more friction, and the more energy lost.
Auto gears are also helical, otherwise they'd be noisy like reverse gears.
Old Feb 26, 2004 | 02:25 PM
  #43
rb1's Avatar
rb1
OK. OK. Now I just want to know how many mpg the extra teeth are chewing up.
If 1% or less of the AT's 5% inefficiency contribution is the result of the gears themselves (e.g. it's 1% the gears and 4% the torque converted), then this side-topic is a rather moot point.
jriv7
May 8, 2020 05:50 PM
cycdaniel
Dec 17, 2019 10:58 AM
Sep 14, 2015 10:09 PM
ninersfgiantsfan
Sep 9, 2015 01:14 PM
