well i determined its my ac clutch coil on my 2006 tsx any advice or tips before i swap it out with a reman" one anyone no how much and what type of oil goes back into the compressor thanks
In principle it should be possible to replace clutch coil w/o discharging the system. you will likely need to remove alternator, maybe pax side cooling fan for access and dismount the compressor to allow access to remove clutch plate and coil.
I would suggest purchasing an Acura Shop Manual. Check ebay for listings. Although manual does not address clutch replacement "in place".
I believe there was a post from someone who accessed the clutch plate to remove a shim. Use search to find the post.
good luck
good luck
good luck
Originally Posted by TexasHonda
In principle it should be possible to replace clutch coil w/o discharging the system. you will likely need to remove alternator, maybe pax side cooling fan for access and dismount the compressor to allow access to remove clutch plate and coil. I would suggest purchasing an Acura Shop Manual. Check ebay for listings. Although manual does not address clutch replacement "in place".
good luck
i just heard they're nightmares to just change the coil and for the same price ive found a compressor
You need to recover refrigerant to remove compressor.
If you don't plan to charge the system yourself, an auto ac shop should recover the refrigerant and charge for a flat fee. Be sure to add some PAG to replace that lost by discharging and removing compressor, perhaps 2-3 oz.
Replace orings on compressor connections.
good luck
good luck
