Tank on Empty
Advanced.
Tank on Empty
I'm not sure if this is a repost or not but I thought the TSX page on Tank on Empty was kind of cool.
How far have you gone with the light on?
There was a thread somewhere talking about what is the most you filled up with.... I know I've personally done a ~15.5 gallon fillup... nothing special.
As an FYI, our fuel pumps are internal (as are a lot of Honda/Acura pumps) and the fuel actually help to cool the pump, so running it low isn't a great habit.
Make a hole, coming thru!
Price of premium gas (average) = $4.06
Price of a new fuel pump = hundreds, perhaps thousands of $s
Living down the shame of burning up a fuel pump to see "how far can you go?" = PRICELESS
Furthermore, the metrics -- "how far have you gone" -- are impossible to compare with a control case, since the TSX mileage can vary from 16 MPG to 34 MPG, depending on driving technique and road conditions. So, using "how far have people gone on "(E)?" to gauge how far YOU can go -- stupid.
I read in another thread hearsay advice that if you fill up when your tank is more than 1/2 full, you get "more gas" since there's less room in the tank for the swirling gas being added to turn to vapor which is reclaimed by modern pump spigots. I'm skeptical of that advice, as I tried that same post's advice to fill up at the slower flow rate ... and added enough gas supposedly to compute to 24.4 MPG when the MID estimated 28 MPG, i.e the pump probably added more gas than indicated ... yes, at a station and pump I've used before.
Originally Posted by litesout
Again flow of fuel through the pump cools the internal components. Kinda like the water going through a garbage disposal cools it.
https://acurazine.com/forums/showthr...3&page=2&pp=40
::Spoiler:: Hardly any.
Originally Posted by JTso
That's exactly my point. The pump doesn't need fuel flowing around it for cooling but it doesn't hurt either. We've had this same discussion a few years back.
EDIT: I found that the actual fuel pump is located within this external housing seen below and has the suction point just at the bottom. So I guess the fuel offers no cooling properties to the external housing since the housing won't actually conduct heat from the internals (ie the case isn't part of the pump cooling properties)?
The TSX has a 17.1 gallon tank. I think the most I've put in at a fill up was around 16 gallons. My very conservative assumption is that the light comes in with just over 3 gallons left in the tank which means that I can safely go 75-100 miles after the light comes on before needing to fill up.
Originally Posted by LukeaTron
Which part is the external housing? Doesn't the whole pump assembly drop into that round opening on the top of the gas tank?
I never even come close to being empty. I almost always fill up at 1/4 of a tank left. I believe I've only had the fuel light in the TSX come on once.
Back in high school when I'd borrow my parents' cars, I used to get so pissed at my dad because he'd never fill up the tank, so when I'd turn on the car, the fuel light would already be on. Not cool.
2021 RDX A SPEC
well i was in downtown Vancouver..off from work.. it's about a 26km drive
back home for me 1 way.
So the moment i pulled out of the parkade, BANG.. i'm at 0km range. I wanted
to fill up at the 'HUSKY' gas station near my home which was 26km away.
So i risk it.. jump onto the highway and keep it at a steady 100km/hr.
Now, in cdn, the size of the tsx tank is 68L. I did about 27km after 0km range
and requested a FULL fillup. Once the gas stopped pumping, it showed that I
filled up 56.x L. Which tells me that i coulda easily done at least another 100km if my 'average' fuel econ is 9.6L/100km.
lol.. make any sense?!
So i risk it.. jump onto the highway and keep it at a steady 100km/hr. ...
But I've only had the "E" light on twice. I usually fill up by the half-tank mark.
Originally Posted by jlukja
fixed
I've never put in more than 56 litres (14.9 G), and the needle was well below E.
NBP 6MT
We have 17 gallon tank? i thought it was sixteen. I usually figure i can go about 50-80 more miles after the light goes on, witch it usually goes on at about 25-30 miles left in the range calculator.
I dont like my car telling me when to put gas, im in control damn it. I guess i can push it even further now that i have that extra gallon
mlody
12-04-2019 02:11 PM
