Switchblade for TSX 04-08
Old May 7, 2008 | 12:31 AM
acuratsx228's Avatar
i just check out Flbusa website and it was updated 05/02/08, and he has the switchblade in stock for Memory 1 keys $115
http://www.flbusa.com/switchblade_key.htm
Old May 7, 2008 | 05:21 AM
skeezin's Avatar
link doesnt work
Old May 7, 2008 | 05:45 AM
moda_way's Avatar
EDIT: Fixed link
Old May 7, 2008 | 10:34 AM
DJ2000's Avatar
NICE FIND.
Question. Will I lose the Driver 1 and Driver 2 function with this key? Does any have one? Is it worth it?
Brandon
Old May 7, 2008 | 11:17 AM
MMsTSX's Avatar
JDM Addict
this is nothing new.
no you won't lose any function at all.
I have this.
It works perfectly.
Just need to get it cut and programmed.
If you have an 04-05 or whatever that doesn't have memory seats,
you can just disable that function on the fob, no biggie.
Old May 7, 2008 | 11:57 AM
ak3883's Avatar
So these are "milled" already, and will any dealer just cut them? I seem to remember from the last thread that many dealers balked at doing this, because it's not the right stock key for the 04-08 TSX.
Old May 7, 2008 | 12:01 PM
MMsTSX's Avatar
JDM Addict
no, not all dealers will cut this key.
because not all dealers cut keys.
my dealer does not cut keys.
any dealer that cuts keys should and probably will do this.
you have to pay them an hour or so of labor to cut and program the key.
it's easy money for them, they'll do it.
if your dealer doesn't cut keys, just have a master locksmith do it.
call around tell them exactly what kind of car you have and that you want
the immobilizer chip programmed. And the key cut too of course.
Old May 7, 2008 | 12:12 PM
DJ2000's Avatar
So bringing to Ace and having them cut this key wont work? It needs to be a specialized locksmith? I can program the key myself I would just need the keys cut.
Whats the cost??
Old May 7, 2008 | 05:45 PM
syee99's Avatar
Whats the cost??
They can cut it - but you'll need someone to program the immobilizer to accept the new key. (note that this is different to programming the remote portion that opens and locks your door and trunk).
I'm not sure I'd give a $100 key to Ace Hardware to cut. If you do, have them do a test cut on a regular blank first.
I got mine cut at a specialty locksmith. He cut it by the key code instead, and also did a test run on a blank to make sure the fitment was good before he cut the one I brought in. Should cost THAT much more. (cost me $4 at the locksmith I went to)
Old May 8, 2008 | 08:48 AM
DJ2000's Avatar
and where do you get this done at?
Old May 8, 2008 | 09:00 AM
DAYTA's Avatar
Dude...read his reply! Go to a specialized locksmith! As far as finding one in your area, you're just going to have to look in the Yellow Pages.
I got my TL Switchblade in the first batch of FLBusa's keys about 1 1/2 years ago, and it's still going strong .
Old May 8, 2008 | 09:32 AM
snakecharmer's Avatar
8th Gear
Anybody in Toronto get this done?
Old May 8, 2008 | 09:38 AM
buste2's Avatar
who dat lil kid?
I have this.
It works perfectly.
hey man,
when you went to get your key chip programmed...did you have to bring your 2 master keys and valet key to get reprogramed?
reason i ask is because i have my valet key used up for my remote start and its a PITA to remove just to get reprogramed...
Old May 8, 2008 | 12:28 PM
syee99's Avatar
I'm in Vancouver, so it's probably not much good for you, but Precision Lock and Key in Coquitlam (for all you guys that live in Vancouver).
They also had their own OBDII programmer for the immobilizer but they couldn't get it to program my keys correctly so I had to go to the dealer to do it. (they were using a Silca SDD device that they said they had no problems with programming Honda keys).
buste2:
If I remember correctly, you have to bring ALL your keys when getting it reprogrammed. I know the 3rd party programmers (like the Silca) require them to clear out all the keys and re-add them back. I'm not 100% sure about the Acura programmers, but when I took mine into Acura, they wanted me to bring all my keys as well. Since each key has a unique transponder chip embedded in the key, they'll require that all the keys be present when programming it.
If you're using a 3rd party alarm, wouldn't the alarm remote control your door functions anyways? Why would you want this key fob? Just wondering...
Old May 8, 2008 | 12:41 PM
chhimp's Avatar
Locksmith did my cut for free. It was a little difficult to cut because of the attached remote. He was still able to cut it. On the other hand, Acura charged about $115 to add the key to the system and I programed my own alarm too. Highway robbery. I wish I had the programming computer and did it myself. I think the max is 4 keys in memory and I didn't bring all my keys in.
Old May 8, 2008 | 12:50 PM
MMsTSX's Avatar
JDM Addict
yes, read my posts.
you'll need to go to:
Acura Dealership (if they cut keys)
OR
MASTER Locksmith (capable of programming immobilizer chips)
after your key arrives from FLBusa you'll need to do 3 things:
1. Cut the key (this is done a special way, from the backstop, NOT the tip!!)
2. Have the IMMOBILIZER CHIP programmed using current software to do so.
(this 2nd step has to be done at Acura or at/with a Master Locksmith)
3. Program the key fob buttons to work. (do this yourself, it's super easy)
the FLBusa site has the instructions you need to hand to the person who is
cutting the key. Be sure to print them out and give them to the key cutter.
the FLBusa site also had instructions for you to program the fob buttons yourself.
Acura or a Master Locksmith will already know how to operate their software to
program the immobilizer chip.
You only need to bring your other keys with you in case the programmer messes up.
They won't need to re-program your other keys unless they make a mistake.
there. now read this post again please.
enjoy your switchblade keys!
Old May 8, 2008 | 01:04 PM
buste2's Avatar
who dat lil kid?
buste2:
its for the girlfriend...she doesn't like to carry a lot of keys with her...but also whenever i go to the dealership for service...they don't like aftermarket alarms...so i always just give them the key...so if i have this...i can please the gf and also if i ever have to leave my car overnight...they have the remote to lock the car since there are a lot of lazy people out there too lazy to push the lock switch on the door
Old May 8, 2008 | 01:06 PM
xenonhid's Avatar
CGP Ebony
Man, I'm still rocking the MODA_WAY Accord Key mod since 2006! Its pretty durable.
Confuses the crap out of the dealership guys.
Thanks moda_way.
Old May 8, 2008 | 02:03 PM
2jiggy4u's Avatar
key
"yes, read my posts.
OR
They won't need to re-program your other keys unless they make a mistake."
I just bought one 2 or 3 months ago?? I took it to a Locksmith, Spent more time in line waiting and them trying to program it for me than it took for them to cut it. They charged me $65 just for the cut! I swear to god it took this "Chick" 20 seconds to cut it! I also had to come back for them to program it for me (which they wanted to charge me for as well) Home Depot could have cut for me for 3 bucks!
Dealers & Locksmiths = Rip offs! :angryfire
Old May 8, 2008 | 02:31 PM
Arcanum777's Avatar
Thanks for the info. Good to know there is a place in town to get it done. Mine is in the mail.
Old May 8, 2008 | 08:47 PM
shalts13's Avatar
tsx'r
or you could make your own..i did..the first one i did it it took me all night... i was nervous...the second time i did it, i did it in a cupla hours tops..
Old May 9, 2008 | 12:14 PM
syee99's Avatar
They're pretty good and know what they're doing. It was too bad their immobilizer programmer seemed to have problems with programming my keys. They guys there had done a few other TSX's before I did mine and he said that he had the same problem with the others as well. (although he was able to get theirs to work)
I ended up having to go to Acura to have the adding of the new key done.
Old May 21, 2008 | 01:43 PM
litesout's Avatar
Oliver!!!
A bit off topic, but does anybody know if the 09 TSX OEM switchblade key will work on the 08? Has anybody tried it yet?
Old May 21, 2008 | 03:34 PM
Egotist's Avatar
^x2
I would like to know too...
Old May 23, 2008 | 12:00 PM
SicK TypeS's Avatar
Not a Registered User
what's the difference between the '09 TSX switchblade keys and the one FLBusa sells?
Old May 23, 2008 | 01:36 PM
buste2's Avatar
who dat lil kid?
we don't know anything 100% yet...
key wise...they're the exact same thing...however...the transmitter could be different...
example...RDX/MDX keys look the same, but the keyless transmitter is useless for the RSX/TSX/TL...
TL keys work perfectly for the TSX/TL/some RSX's...but not for the RDX/MDX...
my bet would be that it would work since the 09 TL will have smart access keyless start...pretty much sure the 09 TSX took over the inventory for the 07-08 TL keys...
Old May 23, 2008 | 01:50 PM
moda_way's Avatar
Thanks moda_way.
Good to hear. I know a few folks have had the epoxy work its way loose, which was to be expected until someone could mill them. Good news is, very simple to re-expoxy or buy this milled key.
Old May 23, 2008 | 03:05 PM
xenonhid's Avatar
CGP Ebony
nah, mine is solid and durable. Whatever you did for mine works great.
Old May 24, 2008 | 07:11 PM
DixonTSX's Avatar
I'm in Toronto (well, Markham) and I bought 2 of the FLBusa keys back last summer.
I just went to a keysmith in a strip mall at Highway 7 & Galsworthy and had them cut the keys, and then I took the keys to Acura in Markham and had the immobilizer and keyfob programmed, I don't remember how much it cost, but it wasn't very expensive.
BUT make sure you disable the memory seat thing on the keyfobs, the dealership didn't know about that, and when they tried to program the keyfobs, kept telling me that they could only get the keyfob do everything except unlock the car, and only after 2-3 hours of pain sitting in my own garage having the car alarm go off everytime I tried to program it, did I realize I had to turn off the stupid memory thing, after that it worked fine!
Old May 24, 2008 | 11:17 PM
Jottle's Avatar
Why would you have to disable the memory function? Do you have an 04-05???
Old May 24, 2008 | 11:59 PM
jmystikcfl's Avatar
So, what would we need to find out about the 09 TSX key to let us know if it'll work in the 08? I'm on the midnight shift this week (so I have plenty of free time during the day,) and I'll be passing right by one of the locksmiths listed on the flbusa site on Friday. If I can find out what I need to know from the Acura dealership, I'd be willing to give it a shot. I can get the blank for about $40, but then the locksmith would have to mill and cut it as well as program it.
Old May 25, 2008 | 12:02 AM
litesout's Avatar
Oliver!!!
Ditto
Old May 25, 2008 | 01:12 AM
terpfan29's Avatar
I just test drove the 08 TSX for the second time today and noticed that the key was separate from the unlock/lock button. I thought that was odd as I haven't seen a car like that for ages. Even my 2003 Accord has the combo key. It's good to see that you can get a key and combine this. Can anybody post a picture of the other side of the key and what it looks like closed? Also can somebody explain what it how the immobilizer is programmed? Thanks
Old May 25, 2008 | 09:44 AM
DixonTSX's Avatar
Yeah, 04
Old May 25, 2008 | 02:09 PM
jimmerz-tsx's Avatar
7th Gear
would this key work on the 07 tsx?
http://cgi.ebay.com/ebaymotors/2009-...spagenameZWD1V
it seems cheaper
Old May 25, 2008 | 02:25 PM
8th Gear
Thanks a bunch for the info. I am in markham as well. Maybe we should have a markham get together.
Old May 25, 2008 | 10:32 PM
litesout's Avatar
Oliver!!!
it seems cheaper
That's what I'm trying to find out. If I knew what I needed to find out, I'd be more than happy to post my results. Which type transmitter and immobilizer does the key need to have? Is there anything else I need to find out? Can the locksmith mill the key?
Old May 26, 2008 | 01:42 AM
syee99's Avatar
Most locksmith's cannot (or won't) mill the key. It's precision milled to tight tolerences so that the key will fit perfectly. I know the FlbUSA version had a few hiccups initially with the key sizes so they didn't fit perfectly.
If you have a decent locksmith, they should be able to tell you what transponder chip is used in the key. The locksmith I went to was able to take my original OEM key, and pass it through a machine that gave the transponder name. He then took my switchblade key and did the same thing with it to verify they were using the same transponder. If you happen to have one of the 09 TSX keys, I'm sure you can have a locksmith try it before milling and cutting it. Ask your local locksmith to see if they have the equipment to do this.
Old May 26, 2008 | 03:31 AM
litesout's Avatar
Oliver!!!
I've got a truly crazy idea. The kind that only comes to you at 4:30 in the morning. Why don't I just ask the dealer if it'll work. Hopefully somebody in the parts department will know if the transmitter matches the one in the fob and the immobilizer can be programmed for the 08. I might just have to do that tomorrow or Tuesday.
Old May 29, 2008 | 11:43 PM
KHAMunist's Avatar
3rd Gear
it sucks for you tsx owners because you have to take it to acura to get it programmed but with the TL key for a rsx is just using a blank milled from home depot and modding it onto the housing and gettting it cut and home depot or something, i always thought the older style model tsx uses a key like the rsx seeing that it would be very easy to do this mod
because i do this mod for rsx owners on , using the TL key mod and telling them they can bring it to home depot to get it cut
