Such thing as a BACK UP GAS TANK
hey guys, just wondering . . .
my gas tank is constantly running out because of frequent driving, sometimes, i find the warning light on. I was wondering how many more miles would my car handle. Is there such thing as a back up gas tank?
You have a about 3 gallons left when the light comes on. And no, there is no "reserve tank" Light comes on, put gas in...Simple...
If you have a TSX with the Nav system you can go into the trip computer and see an approximate range left on your fuel. It's not 100% accurate, but it will give you a general idea of how soon you really need to stop for gas.
However, I would recommend frequent refueling in order to stop the whole running out of gas thing.
Originally Posted by joerockt
Ummmm, yea that tends to happen
But ur right, no reserve tank.
I usually get 50-75 miles after the light comes on myself.
Originally Posted by moda_way
I've found that I have about 5 gallons left when the light comes on ...
You could put it in the left and right cavities of the trunk with a fiberglass shell giving it a clean look like the custom speaker installations. Two extra tanks in the back should give you the gas you need at least to get to a station.
I've found that I have about 5 gallons left when the light comes on and I'm that guy that sits at the pump and gets every last drop in I can.
you'd be interested in reading this article:
http://www.epa.gov/donttopoff/
i find that my light comes on, and tells me i have about 30 miles left in the "range" on my 2006.
then i go fill up, and it takes 13 gallons. according to the manual, it's a 17 gallon tank, so this tells me i still have 4 gallons and approximately 100 miles left. but i've yet to test the theory.
Originally Posted by iamhomin
The light turns up just before you use up 13 gallons, which leaves around 4 gallons in the tank.
I note the odometer when the light comes on and then, conservatively, expect the tank to be empty 100 miles later. This assumes 25mpg for the remainder of the tank but I average 27mpg overall.
If you run it to 0 miles, and check the debug screens, you'll find 2 values; the calculated range and displayed range. The calculated range will show about 20 miles when the display shows 0. (at least on mine.)
Yes, there is a "back up" gas tank. There is a switch below the seat. If the gas runs out, you turn the switch to use the gas in the "back up" tank. I think there is around a gallon (maybe less) in there.
....But you need to trade in your car with a Honda Interceptor to get it.
yea, you have about 3 gallons when the light comes on, but my trip computer was showing that i only had 2 miles left when i got to the pump. Its weird, because i had only driven around 20 milles after the light had come on. I live in pennsylvania, where its kinda hilly..but would it really lower the mpg by that much?
____________
06 acura tsx/automatic
____________
____________
____________
To answer the original question..
Yes there is such thing as a BACK UP GAS TANK.
When your car completely comsume gas and is no longer willing to work with you,
your natural instinct must be, "I AM DOOMED"
However, there is a back up gas tank!
Simply dial TLC via cell phone, pay phone, or even home phone, and say, "I ran out of gas."
In less than an hour, they will come and fill you up with 2 gallons of gas.
or simply.. put the gas in when the light comes on :P
