service A: what is done for this?
Old Feb 17, 2009 | 08:43 PM
handydandy's Avatar
anyone?
Old Feb 18, 2009 | 04:12 AM
nj2pa2nc's Avatar
it's a car-drive it
if they go by the manual-oil change only
but alot of dealers change the filter also
Old Feb 18, 2009 | 01:28 PM
sortudo7's Avatar
Site Lurker, Rare poster
depends on the year of your car but usually it is just for an oil change, tire rotation etc. Basic maintenance they want you to pay them to do that you can do yourself lol.
Old Feb 18, 2009 | 01:46 PM
MMsTSX's Avatar
JDM Addict
A is just Replacing the oil
The codes are as follows:
A = Replace engine oil
B = Replace engine oil and oil filter
Inspect front and rear brake wear
Check parking brake adjustment
Inspect the following items:
-All fluid levels and condition of fluids
-Brake hoses and lines (including ABS)
-Driveshaft boots
-Exhaust system
-Fuel lines and connections
-Suspension components
-Tie rod ends, steering gear box, and boots
and in addition to either A or B showing, a number might also appear, or a couple numbers.
the meaning of these numbers is as follows:
1 = Rotate tires
2= Replace air cleaner element
Replace dust and pollen filter
Inspect drive belt
3 = Replace transmission fluid
4 = Replace spark plugs
Inspect valve clearance
5 = Replace engine coolant
and independent maintenance that does not show up on your MID that
also needs to be done is as follows:
Replace brake fluid every 3 years
Inspect idle speed every 160,000 miles (256,000km)
Adjust the valves during services A, B, 1, 2 ir 3 if they are noisy
all of this information is found in your maintenance journal.
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
thegipper
Sep 28, 2015 01:01 PM
jmaxima03
Sep 27, 2015 10:22 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
