service A: what is done for this?
anyone?
if they go by the manual-oil change only
but alot of dealers change the filter also |
depends on the year of your car but usually it is just for an oil change, tire rotation etc. Basic maintenance they want you to pay them to do that you can do yourself lol.
A is just Replacing the oil
The codes are as follows: A = Replace engine oil B = Replace engine oil and oil filter Inspect front and rear brake wear Check parking brake adjustment Inspect the following items: -All fluid levels and condition of fluids -Brake hoses and lines (including ABS) -Driveshaft boots -Exhaust system -Fuel lines and connections -Suspension components -Tie rod ends, steering gear box, and boots and in addition to either A or B showing, a number might also appear, or a couple numbers. the meaning of these numbers is as follows: 1 = Rotate tires 2= Replace air cleaner element Replace dust and pollen filter Inspect drive belt 3 = Replace transmission fluid 4 = Replace spark plugs Inspect valve clearance 5 = Replace engine coolant and independent maintenance that does not show up on your MID that also needs to be done is as follows: Replace brake fluid every 3 years Inspect idle speed every 160,000 miles (256,000km) Adjust the valves during services A, B, 1, 2 ir 3 if they are noisy all of this information is found in your maintenance journal. |
