Rust spots on top of paint
After handwashing my car, I noticed many rust spots all along the side. Since it's PWP, it's easily seen. Does anyone know what I should use to get them off? I can scratch them off with my fingernail but there's just too many. Any products out there that I can use to quickly get rid of these?
Moderator Alumnus
Actually - it's not rust, but rather environmental deposits (most likely).
I had these on my TSX and here's what you need:
http://www.autopia-carcare.com/inf-clay.html
Also check out the Acurazine Wash&Wax forum:
https://acurazine.com/forums/wash-wax-23/
Thanks for the replies. I thought about using clay but never used it before so wasn't sure if it'll work in my case. I'll give it a try tomorrow.
Thanks again
Thanks again
whatever dude!! clay bar didnt take it off my car. You can could see the rust under the clear coat. the rust never came threw the clear coat. At frist the spots where small. after a year so they started to grow. thank godness for the great service at acura.
These are known as rust blooms. It is probably due to rail dust during the initial transport of the car to the dealership. If not removed early on and left there for a long time, they will "bloom" (get larger). Try the clay bar.
Moderator Alumnus
Sorry you have a rust issue with your car glad Acura stepped up to the plate for you -- warranties are goooood.
Originally Posted by jlukja
I have similar spots on my PWP but they are really small right now. I posted a pic here:http://www.acura-tsx.com/forums/show...280#post392280
Bye TSX, hello domestic?
Originally Posted by TSX7
The pic doesn't work but I think we're talking about the same thing. Does clay put swirl marks in the clear coat?
and PWP definately needs to be claybarred often
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
![](http://img193.exs.cx/img193/9849/tsxbrownspots6rb.jpg)
Boy Genius
I had those all over the lower body of my White Diamond Pearl TL - came right out with a clay bar. If they don't come out, then you have bigger issues and I'd take the car back to Acura.
Embedded rail dust or embedded brake dust. As everyone said, clay bar it. When in a parking lot, check out some of the other cars....they all get it, especially if they use semi/metallic brake pads. I spent 3 hours claying a white Jeep Grand Cherokee, had it all over the sides and back.
As a pro detailer I have to chime in here.....clay bar is indeed the way to go. Clay the crap out of it (use plenty of lube, not water) and follow that with a quality wax and you should be good to go.
Slats
Slats
I was very surprised to find rust blooms on my '08. I first found them along the floor boards, but have since found them all around the car. I removed the ones I saw with some wax and a little scratch with my nail. Can these blooms eventually lead to actual rust on the body of the car itself or are they just a comestic nusance?
Good luck!
Just dial 1911
1 Post
Those rust spots are actually pieces of metal stuck in the paint. If you dont clay bar at least once a year, they will begin to rust.
There is a chemical I use from Valugard, called a dcon system (or ABC system) that can loosen the rust up for clay barring. The "B" part of the system is a concentrated acid that takes care of the rust, but doesnt harm the paint.
nanos
11-12-2015 08:41 PM
pistacio
09-26-2015 09:45 AM
