RSB Help!
Old Jan 9, 2008 | 01:45 PM
GTSX-05's Avatar
ASM 3G TL Type-S
RSB Help!
Hey Acurazine,
Quick question H&R RSB, should I pull the trigger? What are your impressions? How does it compare to some of the other models out there, any opinions or comments are greatly appreciated.
Old Jan 9, 2008 | 02:45 PM
TSXHunter05's Avatar
I would say progress RSB but that just because thats what I have and I love it
Old Jan 9, 2008 | 03:34 PM
steeveage's Avatar
Tormented by mod choices
I think there's only a few people on this forum who have the H&R. Most others have Progress or Comptech. I have Progress, and it's great. But between Progress and Comptech I doubt you'd feel much difference.
Old Jan 9, 2008 | 04:02 PM
ruffellprefley's Avatar
+1 for progress. the great thing about the progress bar over the comptech bar is that it's got some "fins" welded onto it that stop the bushings in the right place, and you don't have any guesswork as with the comptech.
p.s. big thanks to clee109 for helping me install my progress bar recently. great guy!
Old Jan 9, 2008 | 04:44 PM
925tsx's Avatar
B A N N E D
I dont know anything about the H&R but i have the progress RSB and i love it.
I highly recommend it
Old Jan 9, 2008 | 04:50 PM
GTSX-05's Avatar
ASM 3G TL Type-S
What were some of your initial reactions, impressions after installing the progress since most of you seem to be in that majority. How did the car feel? Handling? Extra.
Old Jan 9, 2008 | 05:31 PM
if you're on your stock suspension you'll probably feel the difference more than i did (on tein basics). but it's DEFINITELY noticeable. making quick turns feels much more stable than before. i LOVE loopy on-ramps more than ever now
Old Jan 10, 2008 | 02:17 PM
chuson's Avatar
T.DoT P.I.M.P. lol
You can feel the differences. The differences of noise... lol
I had replaced my Comptech RSB w/ Progress RSB and it is much quieter. Performance wise they are about the same. But Comptech is NOT compatible w/ aftermarket exhaust.
With RSB installed, your car should feel alot connected. When you take a fast corner, the rear is like following the front, on a rail.
Old Jan 10, 2008 | 02:48 PM
CarbonGray Earl's Avatar
Search some of the older threads, because there is alot of info. Back in 04-05 the RSB was usually referred to as the best bang for the buck/install mod. I still think this is the case.
I have the Comptech one, and I have none of the mentioned problems. No noises, no creaks. The bar seemed to make the car more neutral....a little bit more oversteer. The car really feels much more stable and in control in turns, especially those steady-state cloverleafs. Great stability and feedback in turns now.
I also have the A-spec suspension, and I think both play to the TSX's strengths. Any of these bars are likely to be a winner. the only thing I'd note is that the h&r bar is 22mm, which is thicker than the Comptech bar. You ought to look into what this likely means and if you like that effect. The Comptech one is plenty stiff and provides a well-handling ride for me.
Old Jan 10, 2008 | 04:12 PM
GTSX-05's Avatar
ASM 3G TL Type-S
Thanks for the input guys, I just purcahed the RSB and has been offically added to my suspension setup.
Old Jan 10, 2008 | 07:42 PM
speedlimitz's Avatar
for the progress did you guys set it using the first or second holes that bolt to the links??
Old Jan 10, 2008 | 08:33 PM
subdued's Avatar
my acura sanctuary
hey speed... check out this thread. https://acurazine.com/forums/showthread.php?t=40163
everyone states their setting
Old Jan 10, 2008 | 08:39 PM
OoKrnBoi0331oO's Avatar
umm...i think comptech and progress are 22mm...
I have comptech with energy bushings...and they're great.
You'd probably make the best move by getting progress, but have fun
Old Jan 10, 2008 | 10:47 PM
godfather2's Avatar
Time to Climb
whats the h & r rsb diameter? progress and comptech are both 22mm
Old Jan 10, 2008 | 10:56 PM
h & r is 22 as well.
http://www.tirerack.com/suspension/S...egory=AntiRoll
Old Jan 10, 2008 | 11:01 PM
GTSX-05's Avatar
ASM 3G TL Type-S
Yup, its 22mm and I decided to go with it! I have gotten some great advice here on the installation and I am going to undergo this one myself. I will share my experiences with the install and some photos.
Old Jan 11, 2008 | 12:29 AM
hkataoria's Avatar
Total Luxery And Speed
I think u got a pretty good partt buddyyyyyy
Old Jan 11, 2008 | 01:16 AM
ying's Avatar
lol so why did you ask if i wanted to buy it??
Old Jan 11, 2008 | 08:17 AM
GTSX-05's Avatar
ASM 3G TL Type-S
haha thanks man Herpreet.
Old Jan 11, 2008 | 08:18 AM
GTSX-05's Avatar
ASM 3G TL Type-S
I was undecided and thought maybe somebody else could use it, but I am not undecided anymore! and really happy with this purchase.
Old Jan 11, 2008 | 09:15 AM
so you got the H&R?
Old Jan 11, 2008 | 10:03 AM
GTSX-05's Avatar
ASM 3G TL Type-S
Originally Posted by ruffellprefley
so you got the H&R?
Yes I got the H&R
TSXdriver19
Jun 6, 2008 07:55 PM
TCM 01 CL-S
Jun 4, 2008 11:22 PM
TLinNOVA
May 1, 2008 11:05 AM
bluesolara
Oct 27, 2007 01:56 AM
captain
Sep 29, 2004 04:02 PM
