Road trip Experience( Sunny Side Acura(Boston) Vs Bridgewater Acura (New Jersey)
Last week i decided to take my 2006 tsx to Boston.Last 70 mile to go I start getting Wheel vibration at highway speed and also while braking.
Rotor and bake Pads were replaced 4 months ago( 4000 miles).
With No appointment i drove to Sunnyside Acura in New Hampshire. They took my car in $50 just to check what going on( didn't have a choice there). Guy comes back Say All tires Need to be Road Force Balanced and Rotor need to be Re cut. Where i told him the rotor/brake pads are new. He say AS PER Acura NEW ROTOR are Supposed to be cut on the car
. He called Bridgewater Acura and they said that not needed with brand new rotors. Any he came back with a List of thing to be done. Argument went No where.
$271 rotor re surfaced
$64 All tire Road Forced Balancing
$110 Brake Fluid need replacement (was done at 29000 miles now the car has 43000)
So i decided only to go with Balancing
Total $119 ...
Only the way back Car drove with No highway vibration
Braking vibration was minimal.
STILL CONFUSED ABOUT BALANCING ALL THE 4 TIRES.
![what](https://acurazine.com/forums/images/smilies/what.gif)
Total $119 ...
it's a car-drive it
I always have the tires balanced when I get them rotated. The original OEM tires on my 06 tsx lasted 74,000 miles. (rotated and balanced every other oil change). With the Yoko's I now have on the car, I have it done every oil change. My car has almost 90,000 miles. Still have the original brakes and I am getting the brake and manual transmission fluids changed in Nov. (when my car is 3 years old)
I hate when they try to tell you that you need to do things you don't need to do. Balancing is the only thing I would have done.
As for the braking vibration, you might have some pad deposits on your rotors. Try re-bedding them and see if that helps.
Interesting. I had my tires balanced twice at the shop where my brother works (he did not perform the work) and the steering wheel still vibrates (not when braking, just driving) a bit at highway speeds. In my case it should have nothing to do with the brakes or rotors as I had RacingBrake rotors and pads put on the front of my car shortly after the balancing. I wonder what to do at this point because it slightly annoying.
All my tire are new with only 1000 miles
Acura gave me the same crap until I asked them to rotate and balance cause I couldn't afford to replace everything. He balanced the tire and noticed one tire was giving him some trouble balancing. I read in another thread about the tires and rims being easily messed with by the road (curbs, bumps, etc.) and it turns out that I have a bent rim. I have the same problem you do, not so much when I brake but def. at higher speeds lots of shaking. Under heavy acceleration the whole car shakes. Not necessarily a solution but maybe that was what happened?
rockyboy
01-25-2016 06:00 PM
asahrts
09-04-2015 05:55 PM
