Reg Blind Spot mirrors
Hi All,
I am planning to get Blind Spot mirrors for my TSX and not sure whether the heated mirrors cause any problems with these ??
Any recommendations pls ..
I checked few in Advanced auto parts which are about couple of dollars..Will these stick properly when i turn on heating for mirrors during winter ??
Mars
Mars
I use my mirror heaters all the time and have blind spot mirrors. I haven't had a problem with them at all.
I live for blind spot mirrors. I'm 4'10.5", and I have a very hard time looking over my shoulder to see my blind spots, so I have a hard time driving without them.
I had the same concern as you when I put them on, but I figured I didn't care and would see what would happen. I've had my TSX going on 2.5 years now...and put my blind spot mirrors on when I bought the car!
Edit - Also, I've let my mirror heaters on by accident for quite some time too, the mirror heating/freezing never has impacted the blind spot mirror adhesive.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
I Quit
the heat in the mirrors doesn't get hot enough to do anything to the adhesive. The heated mirrors really just get warm enough to get rid of fogging. Example, if you have ice on your mirrors then you'll be waiting a long time for it to thaw. That being said, you should not have an issue with the adhesive backing.
Originally Posted by itsme27
if you are looking over your shoulder to check for blind spots then you are not checking your blind spots right. The way you are safely suppose to do it is to lean you body forward and use your mirror, thats why is there. ![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Littering and.....
I got this from car talk. It takes a little getting used to, but works pretty well. Avoiding the Blind Spot
Yup, that is what I do too, just lean forward while looking at the mirror
This is how I do it...works great!! Haven't "lost sight" of a car yet. My
Yes it is!
I always take a quick glance over my shoulder, and was taught to do so in driving school and the two defensive driving classes I've taken.
Gives me peace of mind to have have direct visual confirmation the lane is clear.
Originally Posted by gostop
I was always taught to look back and it does give me a peace of mind as Deity said.
Let me help you!
Driving school here teaches you to look over your shoulder. In fact, I was taught to lean forward and twist a little to look over my right shoulder when changing to the right lane. The right side-view mirror isn't required (we had one mercedez benz that lacked it).
Leaning forward and looking in your mirror doesn't help when someone two lanes over is switching to the lane you want to move over to. In fact, that might be the reason why I tend to see alot of cars almost hitting each other when they both attempt a lane change. Leaning forward only lets you see a little bit of your blind spot, while looking over your shoulder eliminates any doubt as to what the car 2 lanes over is doing.
Anyone who looks over the shoulder for more than 1 second is dumb. Anyone who only uses their mirror is dumb too. Look over your shoulders for just a second to analyze your blind spot!
By the way, does anyone remember the acronym they taught in driving school? Mirror, signal, shoulder, mirror....something like that.
I have the small rectangle shaped mirrors on my TL
Since I put them on- now its just a check to the side- confirm clear and go
if its not in the blind spot mirror- its not important!
Makes for fast lane change in emergency
I'm all for shoulder-checking when changing lanes. In addition to what was mentioned above, it is only when you shoulder-check that you can spot cars from TWO lanes away from you changing to the same lane as you are about to. Often, in Toronto anyway, people don't signal. By shoulder checking, I can usually "sense" that such a situation is about to occur and I think I've avoided several sideswipes in the past 3 years.
However, I agree the shoulder check has to be lightning-quick. When I was a young driver, I was both driving too fast and taking too long to shoulder check. Ended up locking up my brakes and rear-ending another car. Luckily no damage to either vehicle or their passengers...
Registered Car Nut
The other thing is that most people have their mirrors set wrong. you shouldn't see your car in the mirror, giving you more angle covered with the mirror...
ITSJESTER
17
12-06-2018 02:29 AM
soupi
14
11-15-2015 11:15 AM
