Rear Brakes
Rear Brakes
So after 80k miles, I was told my rear brakes need to have the pads replaced and possibly the rotors surfaced.
Like some posters, I got a quote of $200+.
My front brakes after 80k and change miles are still labled as "green" while the rear brakes are measured as "red"
Obviously I need to get at a minimum the pads replaced and possibly the rotors re-surfaced or replaced.
I was looking at OEM parts at Delray website
http://www.acuraoemparts.com/delray/...All&vinsrch=no
and have a couple of questions...
1.) Based upon the diagram the rear brake pads come as a set?
2.) Of the Pad Sets listed there are two part numbers:
43022-SV4-G22
43022-S84-A50
Is there a difference?
3.) Also based upon the price it seems I could get a better value by getting an after-market set of rotors and pads...
OEM Rear Brake Rotors
Part # 42510-SDA-A00 for $64.15 x2 = $128.30
OEM Rear Brake Pads
Part # 43022-S84-A50 for $46.31
Total = $174.61
Some of the suggested combos are
Rotors- Brembo blanks $54x2=$108
I am guessing the following link would be the right ones?
http://www.tirerack.com/brakes/brake...6&autoModClar=
Pads - Hawk Performance Ceramic Pads $67
Pair the Brembo blanks with
Pads - Akebono ProACT Ceramic Pads $46
For rotors I could also go with the Power Slot Power Alloy Rotor
Some other suggestions include using:
Hawk HPS Pads
Centric Rotors
Akebono Street Performance pads
EBC Green Stuff pads
Have a lot of posters purchased from placeforbrakes.com? It seems like they might have better prices than Tirerack for those parts.
Does anyone have other suggestions on places to purchase from the web?
Thanks for the help!
43022-SV4-G22
43022-S84-A50
OEM Rear Brake Pads
Total = $174.61
Hawk HPS Pads
Centric Rotors
Almost Doctor
I'd recommend going with the Racingbrake ET300 pads from heeltoeauto.com. They're a great performance pad and the rears will run you ~$50. As for the rotors, I'd go with Duralast (autozone) blanks ~$45/pair. The rotors are high quality and have a 2year unlimited mile warranty. Just like the Brembos though, their hats aren't painted or treated so they will rust and turn orange. You can fix that by using a high-temp caliper paint. IMO, the factory pads are crap so I'd save your money and get a superior formulation.
I buy my stuff from Marcus at heeltoe. He's a great guy that stands behind his products and will offer technical advice as needed. I'd avoid shopping at random webstores to save a few $ because if you have a problem, you have no idea how they will resolve it.
What's your budget? How would you say your driving habits are most of the time: Laid back, Spirited, Aggressive, or "I wish this was the Nurburgring I'm driving on"? Reason why I ask is there's no point purchasing rotors and pads made for Aggressive/++ driving if you're a laid back kind of person. If you want bare bones, consider Autozone Duralast rotors and pads. Great warranty and inexpensive.
From people who use them, Racingbrake has positive reviews and is great value for the money. Sure it's a bit more at first for the rotors, but it should last a long time.
I'm currently on Centric rotors and Akebono pads. Still better then OEM in my opinion, but repeated spirited driving stopping performance isn't as good as my prior pads...Hawk Ceramics.
You're gonna get many opinions on this forum. Just my
Budget I would guess would be $50-$65 for brake pads. $55-$70 for each rotor.
Even regular OEM pads have lasted me 80k miles, so I'm not looking at street performance for a daily commuter car.
I just don't know what is better than OEM without going crazy.
There are many aftermarket rotors & pads that are better then OEM in terms of performance. Since you're a 50/50 laid-back/spirited driver, any basic OEM replacement rotor would work; and you can browse tirerack, r1concepts, autozone, etc. Pads do make the difference, but you're driving style is similar to mine .
You should easily find all rotors and pads for you're driving style for under $400, labor excluded.
I may have asked this before but I don't remember, if I go with something like the EBC greenstuff for the fronts, is there any chance that the pitting of the OEMs will be taken off with a more aggressive pad like the greenstuff...keep in mind I think that the braking on the OEMs is good enough for me, I just hate the shuttering on the highway.
Also no brake noise is my highest priority with the same amount or less of brakepad dust as the OEMs.
42510sdaa00, 43022s84a50, 43022sv4g22, acura, alloy, brake, brakes, pads, power, rdx, rear, rotor, slot, tsp, tsx
