Question about Ipod Integration for TSX 2004
I recently purchased an Ipod video and I am now looking to install ipod connection to my tsx.
My question is, should I get Ipod Input Adapters or Aftermarket stereo decks with iPod control?
They seem to cost about the same and I was wondering what everyone thought and why?
Thanks in advance.
Thanks in advance.
Try out the Neo car audio adapter.
http://www.neocaraudio.com/
Originally Posted by PJS
In what respect?
A few of the Honda Accord Owners Club (www.thaoc.co.uk) have bought and installed the USB version, one has the iPod unit (installing in soon), and the general consensus is it's a cracking unit - especially for the money.
I'd been holding off for the Neo, but after contacting the seller about the XcarLink, I'm more than happy with the way it'll operate in conjunction with the Navi and steering wheel controls.
My major concern about all of them was the way in which it would integrate as well as operate.
A recent spell with a VW Golf with factory iPod integration left a lot to be desired - namely the iPod set to randomise track order, but the Golf would always change that to linear mode, so 1-5 was the first 5 playlists, and 6 was the whole library but not randomly.
So, due to the responses I got from the seller, I'm going to be grabbing the XcarLink and at long last, be able to use my iPod in the car.
Just thought I'd let others this side of the pond know there's an alternative to what's already known about and discussed to death.
A/V Section buddy - https://acurazine.com/forums/audio-video-electronics-navigation-22/
Do a search, there's a lot of talk of ipod connectivity for the TSX
So. yeah. i just bought a USA-Spec on eBay. I hope the installation goes smooth. it seems like the big step is to remove that middle storage bin. from what i've seen on that video clip by Neo Ipod, already there is a hole for the ipod cable to run through on top of the bin. is this true?
wish me luck guys thanks.
I ran the cable out the bottom of the console to the passenger side floor. I have enough cable to set the iPod on the passenger seat or put it in the cup holder when I actually have a passenger.
Brum Brum!!
I heard dice electronics is pretty good. havent done it myself but check out the website http://www.diceelectronics.com/ you can never have too many options
Originally Posted by Roci
I'm also going to get a USA spec, but I have a question, Will you still be able to use the CD changer?
I kAnt Spel guD
Originally Posted by Switch
unit works great, not quite as good as the OEM Uconnect in my factory Dodge Charger system but pretty darn close.
built for speed
The isimple adapter mentioned by others seems decent but the way I read the product description suggests it requires a satellite radio equipped car. The '04 TSX did not have Sat radio.
I'm looking at getting the USAspec controller, but can you still control the ipod after its connected? or does it lock up so you need to control it with the deck/ steering wheel?
I've only got a Monster adaptor that sends the ipod signal through the radio, but I'm getting alot of feedback for some reason on every station I try.
USASPEC +1
i got a level four adapter from www.acuraipod.com
it was $130 but it came with everything i needed for install, it took about an hour to plug and play and it worked perfectly the first time.
It charges my ipod, turns off the ipod 60 mins after the engine turns off to conserve battery, lets me control the music through my ipod, but still track fwd and backward via headunit and steering wheel controls.
It is really an awesome product. I have a 04 MT w/Nav w/o satellite
-RW
-RW
Originally Posted by camelboy129
USASPEC +1
-RW
-RW
Was this easy to install? It looks like you have to remove the radio.
Here are 2 questions
Does the USA Spec display ipod information on the headunit of the car?
Do you have to create special playlists for the USA Spec to work? Thanks
