question about euro accord performance...
if i undersatnd correctly, the euro accord has a 190 HP engine, compared to the US version TSX's 200 HP engine...does that mean that the euro accord is even slower than our TSX? and if so, then why do i see people wanting to swap an euro accord engine into their tsx's?
Photography Nerd
I think it's the Euro-R that they're after: http://www.rsportscars.com/eng/cars/accord_euro-r.asp
Originally posted by tc86
oh ok, that would make more sense. i'd definitely take the 20 HP increase despite the 14 lb-ft. loss of torque.
I know its been explained before but I still can't understand why our K24 is'nt making more power than it is. The Euro R/Type R is putting down 220 from a 2.0L while we're at 200 from a 2.4L The only true explanation I can come up with is cost and fuel consumption. The K24 in the TSX is considerably worse on gas than the K24 in the Accord. I'd imagine a 240HP K24 (which I think is possible) would be pathetic on fuel.
Photography Nerd
I think we'll start to see the 240hp k24 engines when the hondata comes out and some cams are available. The 8000rpm redline on the k20 helps the HP numbers considerably. I don't think I would want to change the TSX fuel cut point just because its just not designed to be revved that high but there have got to be a lot of gains to be made by changing the fuel maps.
I'm sure that the main reason that we're not breaking 200hp barrier comes from the fact that we're not able to go through that 7400 cut out. It's a matter of physic actually, more work = more power. And I think the reason that they don't want that is because the risk of blown engine.
In order to have more torque you have to increase the stroke of the piston and reduce the bore. When yo do that you augment the piston speed. Piston speed in the TSX are 22m/s at redline which is very good. Few production engine can get to this speed, the current max piston speed is 20m/s. This is why the TSX max RPM is around 7000. The engine in the TSX is great, you get torque at low RPM and HP at hi-rev.
ld
ld
ld
ld
Form Follows Function
Originally Posted by domn
I ... The only true explanation I can come up with is cost and fuel consumption. The K24 in the TSX is considerably worse on gas than the K24 in the Accord. I'd imagine a 240HP K24 (which I think is possible) would be pathetic on fuel.
European Accord with 2 l engine is MUCH more fuel efficient than Euro Accord with 2.4 engine (or TSX);
http://www.honda.co.uk/cars/newcars/...ptionType=spec
Here are the numbers (range for four variants of Accord with 2.0 l engine).
Urban (mpg)
28.0- 23.9
Extra urban (mpg)
47.9 - 44.8
Combined (mpg)
38.2 - 34.0
Also note CO2 emissions are lower for the 2.0 l engine compared to 2.4 l engine (apparently in Europe data for CO2 emissions must be shown in all the specs - some people there must think that Kyoto should be kept alive...but we do not care and just need more power):
2.0 l
CO2 (g/km)
176 -200
2.4 l
CO2 (g/km)
214 -223
Viscum48, please bear in mind that the data from the Honda UK website refers to Imperial gallon, which is much larger than the US gallon. Therefore, every Imperial gallon would give you many more miles than a US gallon. I expect that the numbers will be much closer once you have done the conversion.
Delta Sigma Pi
Emissions controls on the K24A2 restricts the engine from its full potential. The K24 ECU just needs a reflash or some BOOST (both still waiting). I think a 14:1 fuel mix ratio would do the trick. Damn you Hondata ,
i`m j/k
Check out Comptechs supercharger for the TSX it adds about 40whp for $3995 and its almost out.
i`m j/k
I think it is still quite a big difference compared to what the 2.4 l engine achieves. (The site for Honda UK gives also fuel efficiency in l/100 km)
Whereas the standard K20A (CL7A) or K24 (CL9) engine only has the vtec on the intake side and with a lower compression ratio.
It is not slower as it weighs less than the TSX. My 6MT Euro K24 weighs between 1360kg and 1390kg (depends on which brochure you read).
The TSX weighs around 1465-1474kg (again depends on source).
So around 100kg heavier.
Originally Posted by mel4fun
to the best of my understanding, the Euro-R (CL7R) K20 engine has vtec function on the intake and the exhuast loop of the engine, and a higher compression ratio.
My Accord Euro K24 has a compression ratio of 10.5:1 - same as the TSX. VTEC is the same.
My Euro gear rations are different though.. Does anyone understand gear ratios -what does this mean?
1st 3.533
2nd 1.88
3rd 1.354
4th 1.027
5th 0.825
6th 0.659
Reverse 3.583
Final 4.388
TSX
1st 3.267
2nd 1.880
3rd 1.355
4th 1.028
5th 0.825
6th 0.659
Reverse 3.583
Final 4.7
Moderator Alumnus
Originally Posted by MSZ
If they decided to push the compression ratio to 11.5:1, 260hp on our engine is possible.
At least not with upping the compression alone. For every full point of compression you add, you'll get +10hp, max.
