Question about "Auto" on Navi Climate Control
Pls see this thread for my prob........http://www.acura-tsx.com/forums/showthread.php?t=13666
I noticed today that if i press "Auto" already on the fan would come on at low speeds and stay at low speeds. That was my prob.
Well today I noticed that when I turned the car on w/o turning off the "Auto" it started off at full blast then went to lower speeds which i guess is "normal"
Anyways pls test that out and let me know if thats normal:
-that the Auto would do full blast for a few secs then go a lower fan speed
-and that when you press auto when the car is already on that it wont do that full blast for a few secs then do lower speed.
I know I'm
, but help a fellow TSX'r out.
I know I'm
![Sorry](https://acurazine.com/forums/images/smilies/sorry.gif)
Move toward the window...
Seems normal to me... when on "Auto" mode, it determines the interior temperature using two seperate gauges, and sets the fan speed based on the interior temperature you choose. For instance, if you want a 70 degree interior temperature, and it's 80 degrees inside, it'll blow hard until it gets closer to 70, even when the car is first turned on.
Seems normal
I read your previous thread and I haven't had that experience. However, the two items you've posted in this thread seem to be normal operation, in that, it happens with my TSX as well. When the car is started the AC comes on hard, for 1-2 secs before it picks up the auto setting. I think this corresponds to the navi computer boot time, as soon as I see the annoying navi warning screen, the ac's usually already at a reasonable level. This obviously would not happen when the car is running because the Navi computer is already operational. At least that's what I think is going on. Hope that helps.
I know I'm
I know I'm
Mmmm... tasty.
What iamhomin said... Just let the car handle everything for you. It just tends to go on full blast at first (usually with the recirc on) since the inside of the car is usually warm/hot from being out in the sun.
Auto climate control is the bomb!
![Nod](https://acurazine.com/forums/images/smilies/nod.gif)
BoricuaTL
04-08-2016 01:08 PM
