PWP skirt not matching the rest of the car?
Someone stole "My Garage"
I recently picked up a 2004 PWP TSX and had the dealer install the OEM kit. They put a brand new kit on, although the car is about 2 years old.
I think it might just be me, BUT, the kit doesn't quite match the rest of the car. The kit seems a bit too bright, and the car a very very faint shade of yellow compared to the kit.
Is there any way to verify for sure, or is this possibly just the pearl in the paint causing the different angle to look like a different shade of pearl white?
I think once I clean the car and claybar the existing paint, it might look better, but I was just wondering if anyone else has noticed this with pearl paint before. I've never owned a car w/ pearl paint, and I must say, the PWP is PIMP.
Thanks for any insight.
~Eric
~Eric
I'm the Firestarter
Looks fine on the pictures...
AutoX'er
There is a slight color mismatch. Try using a cleaner wax and then follow it up with a clay bar. You'd be surprised how much contamination attaches itself to your paint in 2 years.
-SWRT
-SWRT
Originally Posted by ndx2
it seems like there's a mismatch... subtle in some of the pics, but very evident in the third pic. got any high res pics?
http://www.pbase.com/curls/tsx_skirt
You can click on the pics and then select a large side from below the pic.
I think a claybar will help and maybe a paint scrub (Mother's Glaze/Polish).
We'll see!
~Eric
Are we all looking at the same pictures. It is definitely whiter with the kit. I assume it is very difficult to match the paint, but the dealer didn't even try to paint the kits with matching paint. They just put on some kit that was already painted. You have two choices. You can accept the difference and learn to enjoy the two tones or you can be dogmatic and send it back to get it repainted to your car's matching paint color.
Good luck
Good luck
It's quite normal, I beleive paint and clear coat fades after a while (sun, soap...). If I remember correctly, if you've been using the touchless car washes very often, your car paint will fade quickly since the soap used is very strong strong (if you leave this soap on your car for more than 15 minutes, your car will need a new paint job). I guess it has to be since to clean your car without using any rubbing.
Originally Posted by mg7726
^^ peter, the kit comes painted to spec. it's just that curls' tsx was bought used.
I kAnt Spel guD
The kit plastic, the car bumper plastic, and the sheet metal all reflect paint a tad different if you look even some silver cars don't have a perfect match b/t bumpers and sheet metal OE paint.
It's normal for the paint to be off a tad, give it a few months and you likely will have swirl marked and dirtied the kit enough you won't notice
Originally Posted by pizzaman555
im a painter and its really tuff to get bumpers to match the car unless you blend into the other pannels on the car
I hope.
Originally Posted by curls
So not worth going back to get it re-done I'd assume... It's REALLY close, and after a good cleaning and polish of the rest of the car, I'm pretty sure it'll be nearly impossible to tell.
I hope.
I hope.
Soul_Deamon
11-13-2018 04:44 PM
nuldabz
09-03-2015 05:49 PM
